メインコンテンツにスキップ
第三世代の Surface Pro タブレットは、2014年6月20日にリリース。
123回答 すべてを表示
締切られた回答
Repair parts needed foe surface pro 3
I am in the data recovery business.
I need the data off of a surface pro 3 but the screen is broken so I cant get to the encryption code.
- I desperately need a new screen & digitizer bonded unit to get this data
Any place I can get this in days not weeks?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I'd recommend getting ahold of a used surface pro 3 that has a bad digitizer, but a working screen and a good working surface keyboard. I have a surface pro 3 that has a bad digitizer, but the screen is fine and with the attached keyboard it works just fine for navigating around. If the ssd is encrypted you will need to carefully put the working screen on the locked unit and go from there. Other than that you are looking for a replacement digitizer/screen assembly on feebay with rush shipping and hope it works for the $400+USD. Hope this helps...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 18
今までの合計 175
