メインコンテンツにスキップ
基板とCPUのための修理ガイド
165回答 すべてを表示
締切られた回答
Weird temperatures with CPU
Hello !
I don't know if this is an issue or not but i have a Haswell i5 4460 and on idle i get 30C , with youtube and a few apps opened i have 40-45c and on max load ( I tried Borderlands And Fallout 4 on ultra ) i never got more than 40C , I use HwMonitor , sould i use another heat measuring program or is my CPU made out of magic and doesn't overheat?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hikary Katsu, those temps look normal , there should be no issues in those ranges.
Haswell i5
Idle Temp 28 to 35°C
Normal Temp 47 to 60°C
Max Temp 72°C
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
I was about to say the same as oldturkey03. The temps sound pretty normal to me. The load temp if accurate is great and you should have a good long lasting cpu if this is the case. You could also try some other hardware monitoring software such as speedfan to see if it reads the same as HWmonitor.
さんによる
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 3
過去 30 日: 3
今までの合計 84
