メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
締切られた回答
Battery does not charge after change
Hi,
i replaced the battery of my iphone 4s. no problem during the replacement process.
After plugging it in again its only showing the battery with 3 small stripes. There is no charging process or other icons like the lightning.
Can someone help me please?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
David, of course you want to double check your work first. After that replace the new battery and see if the old will charge. It is possible that you have a bad battery. The standard way to check will be trying to charge with a different charger (use a wall charger not your computer to ensure a higher amperage) and make sure that you have a known-good cable. Check the dock connector for any broken bend or corroded pins. Clean it with some isopropyl alcohol and a few puffs of compressed air. If all that should fail, you will have to check the charging circuitry on the board. There is always a possibility of pry damage to some small component.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
the bad thing is that i damaged the original battery... so i can not test it..
i also tried several chargers. before the change everything worked well.
I hope its only the battery so I ordered another one and i will try in on monday ..
thank you for your help!
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 98
