unfortunately your touch wizard has stopped
Can't open settings..when I try it says unfortunately your touch wizard has stopped
@Anton Berggren
If you have a Galaxy Tab 3 10.1 try starting the tablet in safe mode and then see if you can navigate to Settings > Applications > Application Manager > swipe right to the All screen > scroll down to find and tap Touchwiz > tap Clear cache > tap Clear data, then OK.
Note: All your Home screens will be deleted.
If no good, try wiping the cache partition and check if that resolves the problem.
If still no good try a factory reset using the hardware keys.
Be aware that a factory reset (aka hard reset) will erase all your user data and downloaded apps. It will restore the tablet to its’ factory default condition (or last system updated condition)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 190
1件のコメント
Any solutions?
Anton Berggren さんによる
