メインコンテンツにスキップ
2008年10月発売。2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duoプロセッサ。
376回答 すべてを表示
Remove/replace stripped hinge screws?
I accidentally stripped the T6 Torx hinge screws on my early 2009 15" MacBook Pro. Is there an easy way to get them out? I'd like to avoid taking it to a professional. They aren't completely stripped -- that is, the holes aren't pure circles yet -- but they don't hold the Torx screwdriver. Would a precision screw extractor work?
Incidentally, is it possible to buy these sorts of screws at a hardware store? I can't seem to find them at iFixit or elsewhere online (at least not without the accompanying hinges, which I don't need).
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
This screw extractor should work fine: http://www.amazon.com/Moody-Tools-58-067...
I don't think you'll be able to find those specific screws for that old of a computer without buying the hinge first, but its less than $15 : http://www.ebay.com/itm/Genuin-Apple-LCD...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I’m having an issue which I believe is due to stripped screws. When closing the top display side, the cover is separating at the hinge from the display side, if that makes sense. Having difficulty finding info on this. Tia
さんによる
コメントを追加
回答を追加する
Michael Fleischmann さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 8
今までの合計 368
