メインコンテンツにスキップ
Released May, 2013. Display - 1200 x 1920 pixels, 10.1 inches. Chipset - Qualcomm Snapdragon APQ8064, CPU - Quad-core 1.5 GHz Krait, GPU - Adreno 320. Memory - 16/32 GB, 2 GB RAM. Android OS, v4.1.2 (Jelly Bean), upgradаble to v4.4.2 (KitKat).
21回答 すべてを表示
black screen and red led blinking 3 times
the lcd was broken after a drop. tried replacing the lcd assembly but now the tablet won't turn on. even with the old screen i can't seem to get it booted. tried al the button combinations but it didn't work. tried unplugging the battery for 10 min. still nothing. when i press the power button the led flashes 3 times, that's it...
any idea's ???
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
6 件のコメント
when you replaced the screen did you disconnect the power before working on the tablet or was the battery connected during the replacement?
さんによる
yes, I disconnected the battery before working on it...
さんによる
Just a question do You know there's a shift button for a reason Ibar
さんによる
Cody, I'm here to help people with their electronics. My first language is dutch, second is french. So please excuse me for my english and if sometimes I forget to write I with a capital I...
greetings iBar
b.t.w. Do you know there are buttons for punctuation? ;-p
さんによる
Yes I do I am sorry.
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
iBar, this can be caused by a bad/drained battery. Make sure that you charge your Sony with a known-good charger/cable.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
all i needed was the original charger :-)
さんによる
さんによる
コメントを追加
回答を追加する
ifixshop さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 30
今までの合計 19,792
