Why Does my phone die very quickly?
My phone dies in an hour in use and five hours without being used after a full charge. What can I do to fix this problem ?
Before you replace anything reduce your screen brightness to a lower setting and close all of your apps that are not in use. Another possibility can be your cellular data usage. If you are always using cellular data your phone will die faster than usual. If this doesn’t seem to work there may be a problem with your battery. If so by a new replacement battery and refer to the Nokia Lumia 520 Troubleshooting to see how to replace it.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 110
