Touch not working after small fall
After a small fall the touch of my 5C not working, the glass or screen are not broken.
I need your help.
Thanks.
Hello mbolanos ,
If possible I would open the phone up and check your LCD/Digitizer connection. Before you reconnect the LCD I would disconnect and reconnect the battery to prevent any lines running through the LCD. If that does not resolve the issue then the fall may have damaged your digitizer(touch sreen).
Best Wishes!
Jordan
このアンサーは役に立ちましたか?
I gave my phone to local service and they said that it cannot be fixed, the touch on the board is dead, but if you have some ideas you can share it cause i really want to save my photos to my PC i have important info on it too
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 101
