メインコンテンツにスキップ
Where can I order a spare battery?
I do not find a place to order a new Archos 50 Diamond battery. The battery is connected with a 6-pin orange ribbon to the phone. The marking on the battery is:
Beijing Benywave technology Co.,Ltd
Polymer Li-ion 3.8V 2700mAh (10.26Wh)
Model: TBT5701
1|CP4/60/76
Limited Charge Voltage: 4.35V
Date: 20150413
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 10
9 件のコメント
Hi Sissou,
how is it going with the battery you bought ? Does it work ?
thanks
Julien
さんによる
Still waiting the delivery...
さんによる
Hi Sissou,
did you receive the new battery ?
さんによる
Yes I received it but it does not work. However it does not mean the battery is not adapted since my phone has fallen in water. I just wanted to test if the battery or the phone was dead.
さんによる
Hi sisssou
I have the same problem with my 50 diamond, the battery is dead.
Please can you give me the adress where you bought your battery
Please thank you
さんによる
4件以上のコメントを表示
コメントを追加
10件の回答
最も参考になった回答
we might not be able to find the exact same battery, however this one looks pretty similar
http://www.dx.com/fr/p/cubot-replacement...
the pin is not on the right side, but I will continue searching for such battery
UPDATE
with the pin on the right side :
http://www.ebay.fr/itm/like/151764079933...
a bit more powerfull too, I can't find the exact size, it might be a bit to large/long
このアンサーは役に立ちましたか?
スコア 5
4 件のコメント:
Thanks, I ordered this one, I'll let you now if it works.
さんによる
great ! I really hope it will just fit right !
さんによる
hi,
still no news from the battery provider ?
thanks
さんによる
Julien, j'ai le même problème que vous ma batterie semble défectueuse. Je parle moyennement anglais mais il ma semblé comprendre que la batterie commandé pas Sisssou était "conforme" mais que cela ne marchait pas pour lui car il avait un autre problème et qu'il avait voulu tester si cela provenait de la batterie. Avez vous finalement trouvé le bon modèle ?
さんによる
コメントを追加
Bonjour aux possesseurs de ce téléphone vendu sans SAV,
J'ai une solution, mais uniquement pour les bricoleurs !
Pour ceux qui ne l'auraient pas encore compris, cette batterie n'est pas commercialisée en France à l'heure actuelle. On ne peut la trouver que sur des sites de vente chinois, mais depuis les déboires avec les batteries de Samsung, il est interdit d'expédier en courrier des batteries par bateau ou avion... Donc si vous n'avez pas prévu de voyage en chine, ce qui suit devrait vous intéresser :
En effet, mon Archos 50 Diamond fonctionne de nouveau parfaitement.
En fait, comme tout le monde, j'ai cherché une batterie en France, équivalente en puissance, en taille et avec le même connecteur.
J'ai trouvé la batterie du HUAWEI MATE S.
Donnée tantôt pour 2620mah, tantôt pour 2700, elle correspond en puissance.
Pour la taille c'est une HB436178 soit 4.3mm d'épaisseur, 61mm de large et 78mm de hauteur. Ca semble trop vu que la batterie du 50 Diamond est une V406075, mais je vous confirme que ça rentre sans problème. (le seul risque c'était au niveau du 61mm de large, car il n'y a que 60mm entre les parois alu, mais en fait ça passe très bien).
Restait la connexion : elle a la même forme et tombe sans problème en face de l'endroit prévu ...MAIS, les 6 contacts (+,-,etc.) ne sont pas du tout dans le même ordre !
Donc ma solution (j'ai bien dit uniquement pour les bricoleurs) consiste à remplacer la partie électronique de la batterie HUAWEI par celle de votre vieille batterie ARCHOS. En fait, c'est très simple, juste 2 soudures à faire !
Donc j'explique pour ceux qui sont restés, pour les autres, merci de garder pour vous vos remarques comme quoi c'est très dangereux, et bien le bonjour à la grande muraille.
Il suffit d'ôter le plastique transparent (jaune) sur la partie électronique des 2 batteries (garder le, vous pourrez le remettre sur la nouvelle batterie).
En tirant doucement sur le petit circuit imprimé, vous allez voir qu'il est relié à la batterie par 2 pattes métalliques (clairement marquées + et - sur la batterie).
Coupez ces pattes au raz de la vieille batterie et au raz du circuit sur la nouvelle. (en ayant pris soin de noter la position du plus. Et surtout en évitant de faire un court-circuit entre le + et le - avec vos ciseaux)
Et voilà, vous vous retrouvez avec 2 batteries pratiquement identiques, enveloppées dans un revêtement aluminium (qu'il ne faut ni couper, ni percer, ni écraser, ni brûler etc. : là je suis d'accord avec les rois de la sécurité).
Reste à souder les 2 contacts qui sortent de la batterie HUAWEI avec les contacts du circuit électronique de la vielle Archos (l'écartement n'est pas exactement le même, il faut recouper les pattes mais c'est bon).
Important : toujours avoir un des 2 contacts enrobé d'isolant, vous souder l'autre, vous l'isolé, et seulement après vous passez au deuxième contact.
Voilà, vous repliez le tout, ré-isolez le circuit avec l'isolant d'origine, puis vous pouvez mettre en place votre nouvelle batterie.
Pensez à la charger à fond (ça vous semblera long et c'est normal : une bonne batterie met longtemps à charger alors qu'une batterie foutue dit tout de suite qu'elle est pleine), puis à la décharger à fond lors de la première utilisation, et voila votre Archos 50 Diamond est reparti pour 2 ans.
Par pitié, épargnez moi le couplé sur les risques d'incendies, les 2 batteries ayant la même puissance, il n'y a aucun risque. Donc si vous avez peur, ne le faite pas, c'est tout. Pour les autres, j'ai des photos si vous voulez (voir lien dans le commentaire plus bas). Mon Archos fonctionne parfaitement, il ne chauffe pas pendant la recharge, et il tient en marche même avec des applis très gourmandes comme les GPS.
Au plaisir
Dernières infos : une batterie est en vente sur Aliexpress à 32€68, mais pour la France, comme je vous l'ai expliqué, seule la livraison par la terre (DHL) est disponible, à 60,49€, soit 93,17€ la batterie !!! Comparé aux 6 à 11€ de la Huawei Mate S, y a pas photo : ça vaut le coup de se lancer dans la soudure.
このアンサーは役に立ちましたか?
スコア 3
8 件のコメント:
Salut Jo Grand-gens,
merci beaucoup pour ta description absolument compréhensible - même pour un étranger comme moi. Je fais partie de ceux que tu nommes "bricoleurs". Néanmoins, je te serais extrêment reconnaissant si tu m'envoyais les photos dont tu parles dans ton article. Merci d'avance, Manfred.
さんによる
Pas facile de mettre des photos ici, j'essai de créer un lien :
https://photos.google.com/u/1/share/AF1Q...
Si mon expérience vous a été utile, merci de cliquer sur OUI ;-)
さんによる
Bonjour Jo Grand-gens,
Dans mes investigations et me fondant sur le voltage 3.8v , l'ampérage 2700mAh , la technologie et le type de connecteur, j'avais trouvé la même batterie que toi HB43618EBW sur Aliexpress que j'ai commandée. Je l'ai reçu ce matin. J'ai effectivement constaté que les polarités étaient inversées au connecteur. J'ai donc remonté le tout en tournant le connecteur et en pliant la nappe. J'ai pu démarrer l'appareil à ma grande satisfaction , mais la jauge de la batterie restant à zéro, je me suis trouvé bien embêté. Par hasard je viens sur le forum pour voir s'il y avait du nouveau et bonheur !!! je tombe sur ton commentaire qui me confirme que je suis sur la bonne voie et me semble devenir la bouée de sauvetage de tous ceux qui possède un Archos 50 Diamond.
Merci pour les photos et les conseils. Je posterai un nouveau commentaire dès que le tout sera définitivement opérationnel.
さんによる
Merci à vous tous qui avez pris la peine de vous inscrire pour liker ma solution, je repasse ici pour vous dire que la batterie du Huawei Mate S, qui fonctionne toujours très bien dans mon Archos, n'est peut être pas la meilleure solution. Effectivement, vu qu'on remplace toute la partie électronique, inutile de chercher une batterie avec le même connecteur. Du coup, si c'était à refaire, je recommencerai avec une sd435774 batterie pour un Vernee Thor de 2800mAh. En effet, alors que la Huawei à 2620mah est un peu moins puissante que la Archos d'origine, celle-ci au contraire est un peu plus puissante !
Enfin, faite comme vous voulez, je ne peux rien garantir pour cette dernière batterie, alors que je peux vous garantir que ça fonctionne avec la Huawei Mate S, donc à vous de voir si vous voulez prendre un peu de risque pour une batterie plus puissante ;-)
Tenez moi au courant.
さんによる
Bonjour Jo,
Je reviens sur le blog pour indiquer que mon Archos marche super bien après avoir installé la batterie HB43618EBW. Quelques remarques cependant:
- j'ai eu beaucoup de difficultés à souder la borne +, je ne sais pas à quoi cela tient,
- le temps de charge est assez long,
- j'ai utilisé l'appli Battery calibration qui m'indique le bon voltage après charge à 100% mais 2000mAh et non pas 2700 mAh ??? Mais néanmoins elle tient bien ma charge;
Merci encore pour tes conseils.
さんによる
3件以上のコメントを表示
コメントを追加
Bonjour,
J'ai trouvé une batterie d'une autre marque que celle d'origine.
https://www.amazon.fr/gp/product/B01GE72...
Je l'ai branché. Donc...
Le téléphone se rallume mais doit être constamment branché avec la prise sur secteur.
Cela m'a permis d'allumer le téléphone et récupérer toutes mes photos, données etc... via la prise usb sur mon ordi.
Bon Courage
Cyril
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Bonjour Cyril,
même problème sur mon 50 diamond, avez-vous résolu le PB avec cette batterie HUAWEI ou est-ce que çà ne marche définitivement qu'en branchant le chargeur (donc aucun intérêt sauf récupérer les données) ?
merci d'avance,
cdlt
Christophe
さんによる
Bonjour, la batterie du HUAWEI MATE S a la bonne puissance et la bonne dimension, mais la connectique ne correspond pas : les contacts (+,-, etc.) ne tombent pas au bon endroit ! Vous pouvez remédier à cela en suivant mon premier message ...cela dit il semble que ce message ait disparu !?!
さんによる
Thank you very much, Jo, for your contribution
I have been looking for a solution a long time. Many thanks for your hints.
I can confirm, your first message was present yesterday, but has vanished today. I guess this might be due to some overzealous admin at iFixit who deletes messages which contain hints on how to open a Li-Ion battery...
It is however, not (yet :-) ) clear to me,
- where exactly you have opened the batteries and
- how the connection between electronics and battery cells loks like in the old battery vs. the new battery.
As I have not looked into a battery pack, I cannot answer (yet) such simple questions like: where is plus, where is minus? Do I see this immediately?
Would you please repost your original message again, please, and add two of the pictures you have taken? That would be fantastic!
Yesterday I have ordered the HUAWE MATE S battery type HB436178EBW over aliexpress.
merci d'avance de la lac de Constance,
Christoph
さんによる
Hi Christoph, if you ordered from aliexpress, you can ordered from Taobao... It's the same. And you can find the right battery on Taobao ! BUT, they both send item from china by boat, and battery was forbiden on boat ! I frigten that you received a message that they can't deliver you. It's appened to me...
Quoi qu'il en soit, vous pourrez toujours trouver une batterie de MATE S dans un magasin spécialisé. Donc je vais essayer de mieux vous expliquer :
Il n'y a pas besoin d'ouvrir la batterie (heureusement)
elle n'a pas d'enveloppe rigide, elle est emballée dans une sorte de plastique collant aluminisé qu'il ne faut pas toucher. Vous avez juste à décoller le scotch jaune transparent en bout de batterie pour découvrir un petit circuit imprimé. Si vous tirez doucement dessus, vous verrez qu'il est relié à la batterie par 2 pattes métallique qui sont clairement noté + - (normalement, vous n'avez même pas besoin de testeur). Voilà, il suffit d'interchanger les circuits des 2 batteries et c'est bon.
さんによる
Thank you, Jo for your recommendations.
However, I have been through this already some monts ago. Taobao offers the right battery, but does not ship it. Dealers on Aliexpress are slightly different. The respective dealer, however, does no longer offer the battery (last shipment of this battery is documented on June 2017), but they do ship batteries with various carriers, even sometimes with express (7-10days).
And many thanks for the description. I have an idea now on how to open the baateries and how to connect the electronics. I am awaiting now the delivery which is scheduled for end of January, I will report here how it went in a new answer to the this question, so that everyone sees it immediately.
Again, many thanks, and have a nice time!
Christoph
さんによる
コメントを追加
I have found and received the 3.8 V 2700 mAh Pour Archos 50 diamond :
https://www.google.fr/amp/s/m.fr.aliexpr...
All is ok for me
Tontonfrancky
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
You can't find a battery on Internet ? Tape battery for Archos 50 Dimond ! And you should find something... And if it doesn't work well ... I know change of telephone is horrible nobody likes it ! But you will have to 1 day...
Good luck and good surching !!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Dear Antoine,
as you might guess, Sisssou most probably already searched for "Archos 50 diamond battery" on internet, and didn't find anything.
Sisssou then tried searching with the exact battery model references and didn't find anything.
I actually did the same as Sisssou, and the only info I found is Sisssou's post.
I feel a bit less lonely, but still stupid for breaking the connectivity port between the phone and the battery, while disassembling the phone to change its screen.
So... no I have a screen, but no more battery.
I'm french, I bought a french phone thinking I was doing something good for a french company, but deeply regret it.
Archos is just the brand to forget if you want to find spare parts.
As Sisssou will, I would be very gratefull if someone can tell me where I can find spare parts like the battery for my phone...
Julien
さんによる
コメントを追加
Here: http://www.dx.com/fr/p/cubot-replacement...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello everyone,
I've found this one :
http://www.aboutbatteries.com/index.html...
However its capacity seems very low in comparison with the one provided at first with the phone...
I have not ordered it yet.
Has anyone tried it?
Many thanks,
Richard
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Dear Richard,
the battery shown in your link has a totally different connector.
And it does not have the same shape, so this offer is a trap.
さんによる
There is several Archos 50, this battery is not for a Diamond!
さんによる
コメントを追加
Has anyone tried a Cubot S600 battery? It looks very similar to the Archos 50 Diamond one: https://nl.aliexpress.com/item/CUBOT-S60...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi everyone,
Same for me; my Archos's battery is out of order. I've tried to find a spare one on internet, but nothing except the "Cubot" one as below.
Does someone tried it? or another solution? I'm really disappointed not to find a spare one - this phone works usually fine.
Thanks for your help or feedbacks.
Have a good day.
Matthieu
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You can buy this battery on next link:
https://www.ebay.es/itm/173380903295
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
sissssou さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 4,250
