charger port not charging
charger port is broken
この質問は役に立ちましたか?
Hi Rebecca,
If you are asking about the actual wall charger then simply use an appropriate USB cable (fits the phone at one end and the computer at the other) and plug one end into the phone and the other end into a known working USB port on a computer that is operating, when you have to charge the phone until you get a replacement charger.
Here is a link to a supplier of chargers for your phone. As you can see they are not expensive. I dare say that it is cheaper to replace it than to buy the parts to fix it.
Using this method to charge the phone takes longer than when using a charger as the port doesn't supply as much current as a charger. You can make it charge a bit faster by ensuring that the phone is switched off whilst it is being charged.
このアンサーは役に立ちましたか?
Charger piece broken can't charge my phone upBLU 5.0 phone
このアンサーは役に立ちましたか?
Please tell me how fix my 5.0 blu phone charger
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 959
1件のコメント
thank you for acknowledging my question
natalieinnis さんによる
