メインコンテンツにスキップ
1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
1203回答 すべてを表示
締切られた回答
Weird noise in optical drive during boot
Hi there.
I own a MacBook "Core 2 Duo" Mid-2007 and I've noticed that when I boot the laptop, the optical drive makes some strange noises.
I've disassembly the drive to see what component makes that noise.
I don't know if it is regular or not, so I've recorded a couple of videos to show you guys how it sounds and in the case it's not regular try to fix it.
There they go:
Video 1
Video 2
Thanks in advanced.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Ok, thank you guys.
The previous owner told me that it didn't sound like that before, so I figured that something was going wrong, but if it is the usual sound... perfect.
Thanks again.
さんによる
コメントを追加
2件の回答
ベストアンサー
Normal start up sound for that model. Replace when it fails to work.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
最も参考になった回答
Hi,
difficult to say since the the audio in the video could be amplified.
Every macbook from that type makes an optical drive noise when booting. If the optical drive works correctly you should have no worries about it.
Best regeards,
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 212
