メインコンテンツにスキップ
Jabra Move Wireless Bluetooth Stereo Headphones. Released in 2014.
How can I take this apart?
I'm trying to take apart the left headphone to fix an audio problem (no sound from left channel). This thing is made extremely tight with nothing visible to start the teardown process. Any help?http://www.bhphotovideo.com/images/image...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 14
コメントを追加
11件の回答
ベストアンサー
Ok, problem for this case has been found and we have solution!
If your Jabra Move headphones not produce sound in left channel in wireless mode - that's bad switching contact in jack connector!
For checking if that your problem and solution too you must try to bend and close contact by hand for left channel pin!
This is jack have 7 pins (has 3 switching contacts for switching mode with cable/without cable)
Connector was found as 3.5mm Female Audio Connector 7 Pin SMD Stereo Headphone Jack or same smd 7 pin earphone socket jack and I found Model number: PJ-382-7P:
You can buy it on the links
  1. http://www.aliexpress.com/item/10pcs-Pho...
  2. http://www.aliexpress.com/item/20Pcs-3-5...
  3. http://www.ebay.com/itm/20Pcs-3-5mm-Fema...
For the disassemble JABRA MOVE headphones please read post by Muro, thank you @mrmuro ;) :
To dissasemble you don't need to unscrew anything, you just have to get the back part of the speaker in one hand and the other part(the one with earspillow) in the other and rotate the second one counter clockwise. If you put the right force you will feel a click and the headphones will be dissasembled.It's not so easy, but normally it could be done without breaking the headphones.
For easy untwisting and for disassembly of the headphones cups you can is not removing ear pillows before untwisting, and tightly hold by hand via pillow. But be very careful to avoid damaging of the ear pillows! To better understand the direction of untwisting, see picture:
Headphones and cups have the three elements of simple mechanical lock:
BTW, for replace jack connector (it has SMD/SMT type) you must be able to work with surface mount soldering, so as not to damage the board! That Is not difficult, for this you must have: a soldering iron with a small tip, good quality flux, solder, and desoldering ribbon. Or better take help for such work from specialist!
'''Important UPDATE:
For me not helped a good flux and desoldering ribbon - for quality soldering you must have the soldering-iron with hot air tip! And unfortunately some contact tracks has been detached when I tried to desoldering of the connector( Because soldering from manufacturer has high-temperature solder!'''
Good luck!
Thank you all for your help!
Good luck!
PS: apologies again for my bad English!
このアンサーは役に立ちましたか?
スコア 11
10 件のコメント:
Thank you @arsdezi, great summary. I'll buy the connector and I'll make the headphones as new :).
さんによる
hi, @mrmuro ! My tip for you if you want replacing connector:
Yesterday had experience and tried desoldering of connector and have troubles with them! Soldering from manufacturer on board have the high-temperature solder, and has very thin board tracks that is very hard for desoldering without damaging!
Good luck!
さんによる
I just wanted to say thank you guys for solving my left headphone issue. It works when the jack is plugged in and it doesn't on wireless. Your info and diagram for which pin is the left pin were helpful in identifying that was my issue too. I tried bending it back and that didn't work, so I soldered the gap in the pin down and I am back in action. I know over time the line in is going to break that connection. However, now I understand why so I'll be more gentle with plugging and unplugging the line in cable into the jack.
I would say if you've been plugging a line in and twisting it around to get both headphones to work and now your left channels is silent while wireless, this is your issue. The left pin connection has a gap in its connection and you'll need to reconnect it.
さんによる
Don't see need to replace whole connector. The problem is behind bad contact in closed state of left channel. To fix it I placed 3.5 jack into connector and pressed to end of the contact to bend it down a bit. The trick is to place gentle enough force when the contact leaf is lifted by jack.
BTW I found cheap lot free of shipping on Ali https://goo.gl/KxFBxq ; there are good soldering irons with adjustable temperature for 12-15USD too.
さんによる
@arsdezi - Thanks! My headset is a denon ah-ncw500 which had the same problem. The jack was not the same, but your description and pictures really helped me to fix mine!
In my case the right channel was dead, and I poked around connecting leads in the jack until the right channel worked on bluetooth. Once i figured out which leads needed to be connected, I soldered a small piece of wire connecting those two footpads on the headphone jack together which solved my issue.
さんによる
5件以上のコメントを表示
コメントを追加
So, the problem was that after using the "Line in" jack for couple of weeks, the left channel was silent when I switched back to Bluetooth. Both channels did perform normally when plugging the "Line in" jack.
Here's what I did just 5 minutes before writing this message:
1) Grabbed and removed the cushion from the left headphone
2) Ignored the screws which stared at me
3) Tried rotating the left headphone off (like in the image user "arsdezi" posted) but %#*@, it's too tight
4) Ignored the screws again; they're not the ones holding the headphone part
5) Put on my winter gloves and try rotating the left headphone off with even more force: success
6) The "Line in" jack has four contacts; with the tip of a screwdriver, I pressed down the contact that was in the "deepest" end of the jack while the headphones were ON and switched to Bluetooth, to test if the sound finally comes out of the left channel: yes, it did
7) Pressed the contact down with force, while soldering some tin on it to hold it down
8) Assembled everything in place
I've had this problem for a while now and even though I've already stumbled upon this message thread months ago, I had some problems with understanding the repair guides here. Not sure if the problem is that they're written in poor English, or if I just can't read English well enough. Probably both, and more the latter.
For months I thought I had to order a new jack connector, pry open the whole %#*@ thing and hope I could assemble it so that it still would even vaguely resemble the headphones I once had. But the repair wasn't hard at all. Didn't even have to order anything.
EDIT: Also realized, that d - amn is a censored word here, even though the word or it's meaning is not vulgar in nature. #justSJWthings ? :D
このアンサーは役に立ちましたか?
スコア 5
2 件のコメント:
Hi, I'm also a Jabra move user. but my problem is on the right channel not the left channel like you. can you help me solve this problem?
さんによる
Hi, I also tried 3). Thanks for tip 5) - some gloves made the difference.
To get contact, I inserted 3.5mm jack and then pressed the end contact with force. No soldering necessary.
Thanks!
さんによる
コメントを追加
I finally did the same thing @mrmuro describes in his comment – except I used a knfe as a cantilever to pry a bit to loosen the glue inside before I twisted it off. It's stuck pretty good.
These are the comments accompanying the pictures in the link:
http://imgur.com/a/UAyGt
"It's hard to see what's going on there due to the clap and tape, and all the glue underneath.
[I removed the] clamp, tape and [pushed] the cable in to make room
in the circle you can see the wire that has gotten caught by the cable when it twists inside the joint. The result of getting caught is that it is tugged, and thus reducing the contact with the soldering point underneath the glue.
I forgot to take a picture of what I did afterwards, but I removed the glue and soldered the blue cable down onto the board again.
when reassembling, try to place the tiny cables in a way so they will not get caught by the twisting black rubber cable in the joint."
Disclaimer: You may have another tiny cable at fault, but in my case, it was the blue one.
Good luck!
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
さんによる
コメントを追加
Hi guys!
Huray! I was able to disassemble and open headphones! Any questions?
But until this time I'm not check pins and cords for resolved my issue with sound: not play left chanel in bluetooth mode, but play all chanels in wired mode.
I will try to solve the problem in a few days(at this week)!
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Hi again)
I found the problem! Only for not working left chanel in wireless mode! Yes, you are right – the blue wire is responsible for the left channel in the wireless mode, but the problem was not in the wires, in my case! The problem is very simple – is Jack! Full-contact (left chanel) in Jack not closes the contact when the jack is not in use, and therefore did not play in wireless! Firstly, try close contact by manual for the left chanel in jack! I hope you have a same solution for similar problem(not working the left chanel in wireless mode) and can fix this problem too!
I will try to desoldering the jack and try to bend the problems contact, but I think that not best solution! May fix it by replacing jack with new jack (with switching contacts of course)!
Sorry for English ;)
さんによる
Hi, you really found it!!! The same problem with mine. I just bent the contact and now it's working perfectly.
I agree that this is not the best solution, but I cannot find such connector anywhere. And it has to be absolutly the same otherwise it will not fit. If somebody finds such connector please share a link. Meanwhile I'll enjoy my WIRELESS headphones. Thank you!!!
さんによる
@mrmuro look my post below! I found new connector for replacing ;)
さんによる
コメントを追加
When outdoors and not around anything solid that can reflect and reinforce the Bluetooth signal from a phone to these (or most Bluetooth headphones), the human body can easily block the signal and cause audio to cut out. This can be shown by placing the phone in your rear pants pockets on the opposite side of the headphone receiver, while in an empty field or parking lot. This is a common problem and many people have discovered it's their body itself "causing" the Bluetooth audio drop outs. I'd like to see if there is a way to open up the cups on the jabra move and extend the antenna across the headband and into the left ear cup.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Thanks guys! This helped a lot! Funny thing is i only plugged in a cable ONCE just to hear how they sound without the bluetooth compression and the jack broke! Ear cushions also disintegrated after a few months! Really crappy quality! i'm thinking of selling them after i repair the jack & buy new cushions.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I've been wondering if I can replace these cushions with something more comfortable. Any thoughts / suggestions after your teardown experience? I'd like to find something like the foam used on the bose memory foam on ear headphones.
さんによる
Ear Pad Cushion for Sony MDR-V150,MDR-V250V and MDR-V300 ; did such replacement twice; http://bit.ly/2wkKROI or http://bit.ly/2xyreXy for bargain prices ;) They fit and work well until your child get phones in his hands - they aren't so firmly\tight fixing in place as originals.
さんによる
コメントを追加
Thanks all, with this step i can replace my Jabra battery, because it was broken. I followed the step to open it, easily by putting the headset in the table compared using two hands.
I also upload how to change the battery (3.7 V, 240 mAh). The things we should noticed is the dimension (original battery is about 16mm x 28.5mm x 6.3mm) of the battery. Because i bought from China marketplace, it slightly wider but it can placed well in mine.
Now i can use bluetooth again..
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
You have a link to where you bought the battery fir the jabra revo?
さんによる
コメントを追加
If you pull the padding off, then twist the earpiece anti clockwise it then detaches from the headphones
. You can then get to the part inside to attempt a repair, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Can you take the earspillows off ? Maybe behind those are the screws...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Took them off, unscrewed and started to disassemble. The headphone jack is under some epoxy however, and i need to fix one of the connections in there.
さんによる
コメントを追加
Hello, I have the same headphone and the same problem (but only when connected with bluetooth, not with the jack). I removed the earspillows, unscrew the three screws that I found but I don't know how to go further, everything seems to be still stuck together.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
I am at the same stage: unscrewed screws, still stuck
さんによる
Hello, i have the same headphones, the same problem also. I managed to dissasemble them, but no luck with fixing. To dissasemble you don't need to unscrew anything, you just have to get the back part of the speaker in one hand and the other part(the one with earspillow) in the other and rotate the second one counter clockwise. If you put the right force you will feel a click and the headphones will be dissasembled.It's not so easy, but normally it could be done without breaking the headphones.
さんによる
same problem here works with cable but not bluetooth also the left strap adjuster is bit stuck.
さんによる
Try to screw some wrench for earcup like I did on the picture:
http://imgur.com/a/1ndi3
Use little hole-key to hold speaker side on surface, use handle to turn from left to right. Apply some VD40 or butter\vaseline on contact surfaces to open it in future just with hands.
Pay attention on screw positionint relative to circle - two are from outside and one just on it (thats a key). Don't tighten to surface - they should allow earcup necks to get behind heads.
さんによる
コメントを追加
I opened it up as described and bent the tab back into place and it’s as good as new. A word of warning, be careful of the speaker wire it is fragile. Thanks for this article.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brendan Reed さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 94
今までの合計 27,976
