メインコンテンツにスキップ
This computer was released by Asus in 2014.
37回答 すべてを表示
How can I install a new Hard Drive/SSD?
I have no where near enough room and I just want more. I would prefer someone else to do so but I don't know where. Any input?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 7
1件のコメント
When the 1TB drive that came with my missus' ASUS netbook took a trip south, we opted for an SSD. The problem is that Best Buy no longer carried that HDD in their inventory. The ones they had were 2 mm too thick and would not allow the back cover to be put back on. So we had the Geek Squad at Best Buy replace the HDD with an SSD. She lost a considerable amount of disk space, but for her needs, she's fine. We will *never* buy another ASUS. That netbook has become the bane of our existence! When it breathes it's last breath, I will remove the SSD and take great pleasure when I beat whatever life remains in it out with a sledge hammer.
さんによる
コメントを追加
7件の回答
ベストアンサー
I have tried to do something similar trying to increase my RAM. I contacted ASUS support just to get even more mad that this issue exists. After the guy disconnected with me while asking if there was anything else he could help me with I just said to myself "I have built a computer from scratch before so I am pretty tech savvy." <---Note the comment... I do not recommend going through the steps I did to try and find a solution because I am 95% sure you will not find a different result from me in the fact that there is no cure to a small 2gb RAM or the standard 32gb HDD/SDD. After I removed the bottom plate (1) this is what I found. So I attempted to remove the battery (2) and this is what I found. (Note in the second picture there are a lot of different connections that even made me hesitant to attempt to remove them). Also in image(2) I was going to attempt to remove the motherboard which is circuit board on the right of the image. This is where I stopped because after removing all connections from the motherboard I found that it was not going to budge and I wasn't sure which adapters (micro sd card reader, mini hdmi port, 3.5mm audio/mic port) were attached and it would be a pain to get those all back in if they came free. This is where I said I am getting past a lot of the stuff that I remember from 12 years ago. I am going to attempt to mark up the first drawing again to label the parts as I know them and what I believe the others are for all intensive purposes. In the markup of the parts the reason I believe that to be the RAM is because I saw the name "SK Hynix" on it and this is a company that only makes RAM chipsets. I am sorry to be the bearer of bad news on this but it is the truth as far as I got. I know I did a lot of searching also to find help to alleviate the issue and the most clear answer I could find was that there weren't many customizable things to be done to this notebook and I believe what they mean was there are NO customizable things to be done to this notebook aside from choosing a pretty color when you buy it. (Note that I didn't even get this option because I was the last in line to get one on the release day of it). I can't post the images here but if I am able to on my profile I will do so and list them as follows:
(1) All
(2) Removed Battery
(3) Detail
Sincerely
Dustin
(Formerly a PROUD owner since 11/27/14)
このアンサーは役に立ちましたか?
スコア 7
2 件のコメント:
I wasn't able to load pictures I will update this post when I have one for images.
さんによる
I bought a used one cheap and just used CloudReady and made it into a chromebook. Boots faster and works better and no Please wait Updating Do Not Turn Off
さんによる
コメントを追加
Hi there,
Under the laptop there is usually 1 or 2 small hatches with a few screws. One usually houses RAM, the other the hard drive. Unscrew the screws securing the hard drive and replace with a new one. You will then need a windows install disc handy to reinstall the operating system.
Good Luck
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
The laptop in question, EeeBook X205TA, has no latches to unscrew. In order for him to get inside he would need to removed the four rubber pads on the bottom and remove the crews underneath. From there he would need to pry the laptop open. However with this particular model everything is pre-soddered so upgrades aren't possible to begin with.
さんによる
コメントを追加
Hi pinedajomer,
Here is a link that shows X205T screen replacement. It may be useful to look at.
https://www.youtube.com/watch?v=xUjSLvBY...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
All report say that the X205TA has everything SOLDERED in place.
No user serviceable, etc..
Ps.. Avoid the BIOS UPDATE, it bricks them
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Pretty simple. You can use the microSD card to store all your important files. And also install any apps. Works with windows 8 and windows 10! http://www.pcworld.com/article/2931453/h...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I'm using the microSD card to store my files but have been unable to get Windows 10 to update. I was able to get it upgraded to Windows 10 eventually but can't remember how I was able to get that accomplished now. Suggestions on how to get programs updated (aka to have them "look" at the SD card)?
さんによる
コメントを追加
is there anybody do, open their asus x205ta bottom plate just to see what it looks like? im also interested if this machine can also upgrade ssd..
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
cannot upgrade
さんによる
コメントを追加
My missus' ASUS netbook HDD started going south after a mere 14 months. We had to have Geek Squad replace the 1TB Seagate HDD with a 120GB SSD. They didn't carry the same drive that came out, or one that would fit. Yeah, she lost a considerable amount of storage space. But for a netbook, 120GB is more than sufficient for her... email, some word processing and Excel stuff. Besides, it's 4-5 times faster when booting up. BTW, we'll never buy another ASUS!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jack Perdue さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 20
過去 30 日: 84
今までの合計 46,719
