No wifi after Windows 10 update
Hi
I've just upgraded to Windows 10 and now I have no wifi connection on my notebook.
Have tried several things suggested on different sites but to no avail, any suggestions would be appreciated.
この質問は役に立ちましたか?
Hi
この質問は役に立ちましたか?
Hi,
You may have to download and install the Win 10 32 bit wireless drivers from Asus, (released 27/10/2015) for your Eeebook to make your WiFi function correctly.
Here is the link.
https://www.asus.com/Notebooks/ASUS_EeeB...
If you are experiencing any other problems with your Win 10 installation you may wish to revisit the Asus download page above and download the appropriate Asus drivers for your Eeebook rather than rely on the drivers supplied by Microsoft that come with Win 10. After all the manufacturer knows their product best.
このアンサーは役に立ちましたか?
Hi
I am unable to connect to the Internet on this eeebook, therefore I cannot download the drivers, if you know of a way to do this I would be most grateful!
Thank you in advance.
Hi,
If you can access another PC with internet access and you have a USB flash drive (USB stick) then you can download to that, then connect the USB flash drive to your Eeebook and then install the drivers from it. In the Eeebook you go to Cont. Panel > Device Manager > Network Adapters > your wireless adapter > Drivers > ight click > p ope ties > D ive s > update drivers, it will allow you to point to the USB drive as a source of your drivers
Hi,
To access Control Panel, press Windows Key and x key, window will open on left of screen with Control Panel shortcut down the bottom. Sorry about the above comment, problem with website won't let you enter the letter "r" when you edit a comment.
Should read Control Panel > Device Manager > Network Adapters > highlight the " name of your Wireless Adapter" > right click > Properties > Drivers > Update drivers
The problem is with default driver supplied with Windows 10. If you are facing issues after Windows 10 update or upgrade, the I suggest to check this video, that has step by step guide to solve the Broadcom WiFi driver issues - amazingly simple actually-
Panel > Device Manager > Network Adapters > your wireless adapter > Drivers > ight click > p ope ties > D ive s > update drivers, it will allow you to point to the USB drive as a source of your drivers http://driverrestore.com/update-asus-dri...
I hit similar issues i uninstalled windows 10 drivers and then installed windows 8.1 drivers rebooted and it worked.
このアンサーは役に立ちましたか?
Thank you so much you solved my problem!! Yes just delete the win10 version and install the win8 version
This is what worked for me too.
Great. Thanks
Select the Start button > Settings > Network & Internet > Status. Under Change your network settings, select Network troubleshooter. Follow the steps in the troubleshooter, and see if that fixes the problem.
Regards,
Will
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 14
今までの合計 40,021
2 件のコメント
https://www.youtube.com/watch?v=_KaXpFJj...
No Thanks さんによる
this helped me solve the problem as well http://driverrestore.com/update-asus-dri...
lissacoffey さんによる
