there is gap between the top and the case
there is gap between the top and the case on the front can this be fix
Your question is a little vague, but I'm assuming you mean a gap between the uppercase (with the trackpad built in) and the lowercase, not that the laptop does not close/latch completely.
This guide should walk you through removing the uppercase:
PowerBook G4 Aluminum 15" 1.5-1.67 GHz Upper Case Replacement
Inspect the parts for bends/damage, re-assemble correctly.
このアンサーは役に立ちましたか?
+ good
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 769
