メインコンテンツにスキップ
Water Dispenser dispenses water slowly
I have a GE PFSS2MJXASS Refrigerator and the water dispenses slowly. Ice maker works fine. I recently replaced the water filter and valve and that did not fix the problem. When i unscrew the water filter and replace it the water dispenses fine for a short time and then the flow slows down. I hear air when the filter is connected to the refrigerator so i suspect the problem is with the part that you screw the water filter into. Any ideas on how best to fix would be appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
You need to flush the air out of the water lines after installing new filter. Place a tall/large cup under the water dispenser and run the water untill the air is released. It usually takes 5 minuets or more and at least a gallon of water to remove all the air.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
markrubin25 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 52
