lost windows windows corruption
how can i restore windows
この質問は役に立ちましたか?
Get the appropriate windows disk for you OS then set your boot menu to boot from the optical drive . Once there select repair firs to see if your problem can be fixed that way if not then you will need to go to advanced and format the drive then reinstall windows. Make sure you have a valid oem key before starting . Hope this helps
このアンサーは役に立ちましたか?
Thank you I will have to get Windows disc and try this
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 83
2 件のコメント
What version of Windows is it? How far does it get into boot? Do you know the cause of corruption?
gatewaynomad さんによる
Windows 10 I can't get pass utility screen
betty alston さんによる
