メインコンテンツにスキップ
2012年11月に発売されました。GoPro Hero3はWi-Fi対応、4K解像度のデジタルカムコーダーです。
104回答 すべてを表示
It keeps turning off and on by itself
Out of nowhere, when I power on my GoPro Hero 3 Black, it turns off and on, repeatedly, by itself, until I remove the battery.
There was no shock to the camera when it stopped working, no water damage, maybe a hotter than usual day, but nothing crazy.
Video here: https://www.youtube.com/watch?v=YKSffmH0...
I've tried:
  • removing the battery
  • removing the SD card
  • different battery
  • upgrading the firmware (didn't work, power cycles but with the firmware upgrade process)
  • tearing it apart and looking for loose/broken connections
No luck.
Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
11 件のコメント
We are experiencing the same problem. Did you ever get a solution ?
さんによる
No solution so far :-/
さんによる
same problem with me, still waiting for a solution
さんによる
same problem! need a update now!
さんによる
Hello
Do you have any accessories attached to the camera at all
さんによる
6件以上のコメントを表示
コメントを追加
8件の回答
最も参考になった回答
I have the same issue and have tried numerous different sd cards, brand new batteries with full charge, taken trhe camera apart (every pcb disconnected and removed, checked all terminals and battery terminals, no faults found.
I have tried updating firmware (currently on v 03.02 and still it switches off and on constantly.
I have now decided to give up and my only solution seems to be a new camera and it wont be a GoPro.
Thank you all for your input :-s
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Just had this problem, but the camera stayed on when I took the memory card out. On a hunch I tried another sd card, and that seemed to do the trick. Not sure what caused the problem in the first place, as it was working fine moments before.
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
Not the same issue. I mentioned in the original post that I've tried it without the SD card
さんによる
It is kind of the same issue. May just be a different root cause. Looked at your video and it looked pretty much the same to me. Different card fixed it (which you hadn't mentioned that you'd tried), so I thought that I'd mentioned it. Just trying to help. Wish that I hadn't bothered.
さんによる
Hey, sorry if that came out wrong, I didn't mean to sound rude.
さんによる
No worries :-)
さんによる
My hero 3 suddenly started beeping, it was in a drawer & had been there for a couple of weeks. When I press and hold the mode button, it beeps and turns off - then immediately turns back on again? I have the larger battery piggy backed onto the camera, and if I remove this, the camera operates normally???
さんによる
コメントを追加
Yes, the battery contacts inside the unit might be loose, More than likely the medal contacts are bent out of shape or not touching depending on the angle that the unit is set. You could measure the distance of the contacts from the base if you had some kind of measuring tool. I bet one side is depressed in too much or more than the other.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Tried 3 different batteries, same result.
The contacts on the gopro also look flawless as seen here: http://imgur.com/a/wtDji
さんによる
コメントを追加
I dropped my camera one day and it starting turning on and off from that day. There's numerous thing that can have caused why is it doing that.
1. Battery (rechargeable type - lithium ) this could be reaching its maximum lifetime change it.
2. The battery terminal where the + side of the battery should touch is loose and the spring tension is wont hold when the battery is inserted.
3. The battery doors is loose you may need to replacse the battery doors
I found mine got the battery not touching good enough on the terminals as it is supposed to have a constant and steady touch on the terminals positive side. What I did is I folded a piece of aluminium foil wrapper just thick enough to get a good push of the battery and it solve my problem. But this is only applicable for the built in type of battery. You place an aluminium foil wrapper behind the battery before you close or or slide the door in.
This is not recommended by the manufacturers. But it did the trick on my camera and it solves the lingering problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I just had an issue yesterday, my go pro keeps turning on automatically after it has been turned off (it doesn't turn off automatically). Found out that it is because of the extra battery pack. The extra battery pack is empty of charge. So I charged the extra batt pack and it didn't turned on by itself again.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Why does my Gopro 3 Hero + turn on by itself with the extra battery on only….
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
My 3+ does the same thing ..
さんによる
コメントを追加
Same problem here, i just bought 2 new battery packs and i’ll let you know as soon as i’ll try them
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi, just resolved the on /off problem with my go pro hero3+. The additional battery add was uncharged whilst the integral battery was fully charged. Remove add on battery and charge up and the problem is solved!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Emil Burzo さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 38
今までの合計 17,968
