メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1233回答 すべてを表示
締切られた回答
Screen lifted from the phone
So my screen is lifting up from my phone a bit on the top. I was in school & I dropped it due to getting bumped over & it being knocked out of my hand onto the floor but, when I picked my phone up I took my case of to check on the phone & seen the screen lift then when I tried going on my phone it was difficult to use, I try swipe or push on my phone to use it and it doesn't really work, then it will either freeze or glitch while I try, I don't know what's wrong with it? I can barely use it. Also would I have to get a new screen if possible?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hey Aailyah,
It sounds like your digitizer is broken. This can either be solved by making sure the connector is all the way on or by simply replacing the screen. If you are comfortable repairing your own device there is a great teardown here on iFixit and you can order quality parts through eTech parts or iFixit's parts store. If you have any other questions feel free to ask or check out youtube.
Hope this helps!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 115
