Samsung galaxy s6 earbuds one side not working
cant explain it very well so im going to show you
could you show me how to teardown the bud?
Sounds nasty but i just blew and sucked the main speaker and they sounded great again!!
このアンサーは役に立ちましたか?
Not for me...
me either ..
it worked for me!
This was crazy helpful. I thought I was going to have to buy new earbuds!
Worked for me. Alternating between blowing/sucking for 30-ish seconds and they work like new again.
I just blew and sucked the main speaker.. works like a charm
このアンサーは役に立ちましたか?
Blow and suck and main speaker for 10-20 sec each while alternating. It works for apple earbuds to for future reference
i could not for the life of me get this stuff stuck in my earbud out by doing that
nevermind i kept trying and it finally worked
The earbuds are made of molded plastic pieces glued together, and attempting to disassemble it would most certainly render the headphones beyond repair.
The jack on your phone doesn't seem to be an issue, since part of the earbud is functional.
Unfortunately, you will have to buy new earbuds.
このアンサーは役に立ちましたか?
I have two of these earphones and both have weaker or no sound in the right bud. It appears that everyone else has a problem with the right bud as well, and I find it odd that the same bud gets broken with everyone. Im convinced that the earphones themselves are quite bad on the right bud and somehow easier exposed to damage.
I still have my earphones from the galaxy s4, and they work just fine despite being old by now. You'd think new models would be less fragile, but I sit here with two pairs of new, broken earphones, and one pair of working old ones...
このアンサーは役に立ちましたか?
Same with mines and i got them with my s8. Akg ones. Rigth one has faint audio
I trid a combination of both the blowing and suucking aswell as using a toothbrush to try and get in the holes to clean them if that was the case and it worked for me
このアンサーは役に立ちましたか?
Get a lighter and go over the part With no sound this helped me
このアンサーは役に立ちましたか?
it do not work
last time i did that i was trying to melt// burn of the wax, ended up with my earbud catching fire, even tho i did fast passes. Not recomended, seeing as it is highly dangerous.
Its really easy to fix it i had the same problem one side didn't work so just clean it from inside alright by the time you use the earbud it gets dirty :D so just search how to open it safely and clean it maybe with a tissue paper
このアンサーは役に立ちましたか?
I found when I took my earphone for when I had this problem It was impossible to put it back together.
このアンサーは役に立ちましたか?
I need help. My earphones is making no sound when plugged in, but when i move the cord around it starts to make a static noise. Plzzzzz help
このアンサーは役に立ちましたか?
The part of the speaker that doesn't work blow on it or keep blowing on it for 30 seconds.
このアンサーは役に立ちましたか?
my left side is working the my right one with the microphone does not work at all.
このアンサーは役に立ちましたか?
This problem is usually caused by wax blocking the holes in your earbuds. You can use a sewing needle to poke through the holes in the speaker when the headphones aren't in use and you're good to go. The sound will be just like new again!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 14
今までの合計 62,479
12 件のコメント
Before you go tearing it apart check to see if your getting it plugged in all the way if you have a case sometimes the case will keep it from plugging in all the way
Jimfixer さんによる
I got the problem to did you fix it?
ramazan2000 さんによる
Mine right bud has very faint audio, basically the same issue.
Anjali Viswan さんによる
ive got the same problem the upper speaker wont work plzz anyone
even if i plug it all the way no result
nelisz さんによる
hi there
i am just wording could anyone help me i have a pair of Samsung s6 earphones and one is not working can anyone help me asap i really needs them
thanks
lauren mcgowan さんによる
7件以上のコメントを表示
