メインコンテンツにスキップ
Thin and more powerful than ultra-budget laptops.
20回答 すべてを表示
Why does my Laptop only work when the charger is plugged in?
My laptop only turns on when the charger is plugged in and even then it fails to charge. As soon as I remove the charger from my laptop, it completely shuts down and I have to once again turn it on by plugging in the charger, pressing the power button and continuing to keep it plugged in until I stop using it....
Why won't it charge at all, and yet why does it only turn on with the charger plugged in?
The green light on the charger lights up when the cord is plugged to the laptop, which means that charger is working. I think it may be the battery but ive tried to reset it and take it off the laptop and then put it back on several times but still the same result.
PLEASE HELP ME IF YOU CAN, I'D GREATLY APPRECIATE IT! Thanks :)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
5件の回答
ベストアンサー
Replace the battery, they're cheap: http://www.amazon.com/s/?ie=UTF8&keyword...
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
excuse me i have same problem but my battery is proper what might be the reason
さんによる
Roshan, it would be best to start a new question so others will see it. I don't have an answer right off the bat.
さんによる
コメントを追加
My new Lenovo did the same thing after having it for one month. Tech came and replaced the motherboard today. Still doing the same thing.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My laptop only works when it is plugged in, i bought a new battery and it still only works when plugged in.
And now their is a X on the battery icon. Can you Please help me and tell me why that is ..
Thanks in advance!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the same problem, it was fixed after I bought a new battery, it was saying before I booted it up that the batter wasn’t working properly anymore, so when I got a new batter the problem was solved. This happens because of 4 reasons
# Battery was physically damaged (like your computer fell or something)
# Battery has reached it’s full potential and the lithium-ion has died, so it can’t be charge anymore
# You keep your computer plugged in when it doesn’t need to be charged so the battery overheats and after too much over heating the battery basically dies.
# Your computer has been hacked or infected with a virus, and when the motherboard blocks connection with the battery it cannot receive power from it. I don’t know how hackers do it, but somehow they can block connection from your battery to the motherboard.
  1. The only other way you can get this fixed without replacing the batter is calling a technician and seeing what they think about the situation.
  2. Hope this helps. :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I don’t know why but my laptop did the same thing. Then the hinges started breaking. We noticed that some screws on the bottom were missing. I replaced them and the hinges were back to normal. After than I checked on it and the laptop was working without being plugged in 24/7! I don’t know why it worked but it did. Check your laptop for missing screws!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I'm having the same issues with my Acer laptop, which I did bought a new battery but it still not working without changing
さんによる
コメントを追加
回答を追加する
AquaBlue さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 15
今までの合計 31,990
