Not charging, MagSafe led is green, working only with charged battery
Hi everyone,
I have a Macbook Pro 13" Early 2011, problem is "Battery is not charging".
When I connect MagSafe adapter, green led appears and no amber/orange led turns on.
I removed the battery and plugged into another Macbook Pro, It seems charging and functioning normally. I have fully charged the battery on working Macbook Pro and plugged back another Macbook Pro. System is starting normally, but "Battery is not charging" label appears on top of screen. MagSafe led is green and battery is discharging. When the battery is completely discharged, there is no way to power on the unit. Only working with charged battery.
I did SMC, PRAM reset. No luck.
I think it's a logic board problem.
Please help. (I have electronics skills.)
Update (11/18/2015)
Battery is charging perfectly on working Macbook Pro.
I measured current sense resistors with multimeter on faulty Macbook Pro. One of them about 2.5ohms, another is about 50ohms. Are these correct?
Update (11/19/2015)
R7052 current sense resistor was causing the problem. I've measured it as 50 ohms before. I've replaced it with 0 ohms. Problem SOLVED!
この質問は役に立ちましたか?
1件のコメント
Bravo... It workes for me . Mine was macbook pro early 2011 .. Amd board was 820-2565A.. I think mine board was damaged due to power surge because after that i order magsafe adapter which was damaged and my macbook works for some few days because of remaining charge in battery.. Then i order new battery cos i thought it might be due to battery failures.. With new battery it again works for sometime and the same issue .. Then only i got to know that the issue is of charging not of SMC, PRAm, charger or battery.. I bypassed the resistor with screw and kudos.. It starts charging and orange light appeared on magsafe port.. Thank you so much dear.. You save the day..
vivek2006goyal さんによる
