Why does my speaker keep rattling?
Every time I try to play music on my speaker it begins to rattle. It makes the music sound funny and keeps me from using it.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
There could be some dust inside the face plate that is making the speaker rattle. Remove the face plate and clean around the speakers to fix the problem.
このアンサーは役に立ちましたか?
It sounds like damage to the speaker cone inside the device, was it dropped by any chance? Either way you will need to contact whoever you purchased it from to see if any repairs or replacements can be done as the speaker inside this will be proprietary. Without a donor speaker from another unit there's not much more you could do.
If you have no warranty and no replacements / repairs can be done by whoever you purchased it from, it would be worthwhile opening it up and having a look to see if you can spot any physical damage. Then report back here with an update on the issue / provide pictures of the damage.
このアンサーは役に立ちましたか?
Try another device..
Had the problem with my Pandora7 connected to my Note 5
but a laptop connection was flawless
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 13,746
