メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
Screen damaged and display non-functional
My daughter's LG G2 was dropped face down and run over by an SUV. The screen and display are non-functional. The phone rings but have no way to answer to test the speaker/microphone. Is this worth even trying to fix or do I just give her my old Motorola Droid until it's time to upgrade (May 2016)?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Unfortunately there is no sure -fire way to test the components you listed with out a functional LCD and Digitizer. The fact that the phone still rings is a good sign. It means that the phone is still on, the cellular modem is functional, and the speaker works. Given the fact that the speaker connects to the mainboard via the same flex cable that the microphone is on, there is a good chance that the mic still works.
My advice is to open up the device and take a look at the components. Look for any physical damage to the mainboard or flex cables. Also, check the battery and make sure it has not begun to swell. Sudden impact to the battery such as a car running over it may cause it to begin to swell up. In my experience the G2 is pretty resilient. So, if everything looks good on the inside, go ahead and get a new screen.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Guess I'm going to give this a shot. Thanks for the input Dylan.
さんによる
You're very welcome!
さんによる
コメントを追加
回答を追加する
tedbelales さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 16
今までの合計 269
