My speakers are not working right!?
When I turn the volume up on my player, it still won't produce sound, what should I do?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Are you using headphones? Make sure your headphones aren't just faulty by testing them on a different device. Also, make sure your volume is turned all the way up by using either the remote or the dial on the side.
If it is none of these issues, you may need to replace the speakers. You can do this by following this guide.
この回答は役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 234
