Why does my controller not want to link to my xbox sometimes
my controller works when it wants to it disconnects from the xbox and wont connect bac to it i have to keep scanin for it why is that
Mine was acting strangely like that as well. I found that my TV had to be set to the input the Xbox 360 was connected to for it to connect. For example if I was still watching cable and tried to sync the controller so I could watch and wait, it wouldn't work unless I switched inputs to the HDMI my Xbox is connected to.
このアンサーは役に立ちましたか?
@jp simpson same as me what is the company of your tv?(TCL Etc...)
@jp simpson worked perfectly for me, thanks! I have a seiki tv. Thought my whole system was busted
Dude thank you much ive been trying to get my xbox working for like three and half hours I tried everything but nothing was working. And then I tried your idea and it worked. Thank you so much
I have done every thing and it was working when i got it and i got on it but just acting a little wired thats all but payed fine and worjed fine . I got this morning to play skyrim and it got to the load screen and froze so i turned it off then back on and now none of my four controllers will connect. And they will turn it on but wont finish syncing or anything else.
Put fresh batteries in the controller. If you're using a rechargeable battery pack or rechargeable AAs, try swapping in a new pack or alkaline (normal, non-rechargeable) batteries to see if those are also affected. If the controller works better with alkaline cells, then your rechargeables might be worn out.
このアンサーは役に立ちましたか?
My controller shows that it connects to my Xbox 360 because all four lights around the home button flash at the same time in sync with my Xbox then it doesn’t connect
Me too 3ala fekra
The easiest way to sync them is with a plug 'n' play cord plugged directly into the 360, and then turn it on. When you unplug the controller (once the lights on the controller light up), it will be synced with that 360. Sometimes it will take a moment to boot the 360 from the controller without pressing the power button on the 360 itself.
While you're at it, in reference to the rechargeable batteries, try scrubbing the copper connectors, and plugging in the controller several times in order to fully recharge them.
A lot of the times, the rechargeable batteries will "finish" recharging, but not hold much of a charge. When it does, unplug and replug the controller until the light stays red and fully charges.
このアンサーは役に立ちましたか?
My controller will not pick up my Xbox 360 I've tried to use a cord and the wireless I put new batteries in it the lights come on but nothing I've tried to reset it also but will not work help
このアンサーは役に立ちましたか?
Did you ever fix it? Mine is doing the same.
Did you guys figure it out?
i have the same issue
I got it!!All you need to do is turn on both the Xbox and controller. Then press the connect button on the Xbox. Then press the same thing on the controller. It should work. I had the same problem.
Hope this helps!! :)
このアンサーは役に立ちましたか?
Doesn’t work I’ve tried it like ten times with my controller and my Xbox 360 still won’t connect nor even with a usb cord
I found that the connection drops during playing and realised that it was when I was getting a bit physical with the controller (ie shaking it about a bit). It seems that the battery connectors come apart from the batteries when you shake the controller. To see if this is your problem just ry shaking the control quite hard and see if it switches off?
Take of the battery holder and use a small screwdriver or a knife tip to open up the metal tab in the middle of the battery holder a tiny bit more, then refit and enjoy.
このアンサーは役に立ちましたか?
Yes I used it at my family's house and when I came back home to use it , my cousin said I had to reset it . How do I reset it back ?
このアンサーは役に立ちましたか?
Henry Freeman, take a look at the answers on here Why does my Xbox guide button flick on and of?
I have a controller that kept disconnecting. I used a cotton swap dipped in rubbing alcohol & cleaned the battery contacts in the battery pack as well as the spring contacts under the battery pack. This seems to have worked for me. It has not given any further problems unless the batteries are near dead.
このアンサーは役に立ちましたか?
My controller wwouldn't sync, it would turn it on but not sync, then I remembered that I unplugged the hd cable out (to watch something on a different system) and didn't put it back in to my 360. So plugged it back and everything is working again. Hope this helps.
このアンサーは役に立ちましたか?
I was having the same issue and remembered how I fixed it. When trying to sync your remote you have to have the tv on an input set to the xbox. Hope this helps.
このアンサーは役に立ちましたか?
Sometimes interference from other electrical devices will cause that to happen but rarely.
Other times it could be a low battery charge.
It could be the actual controllers built in Wifi beginning to fail.
You might have to resort to using a play and charge cord to bypass theWifi altogether.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 8
過去 30 日: 49
今までの合計 71,087
4 件のコメント
Do you use this controller with another xbox 360?
Andrew Guenther さんによる
Yes I do at my friends house
Caiber X Gaming Clan さんによる
I have the same problem recently my controller got broke and it died before it got broke and I'm trying to connect my new Xbox 360 wireless controller to my Xbox 360
Jacob lowery さんによる
Do the hdmi thing that JP Simpson said it works!!! I tried everything before that and nothing
Taylor Alexandra さんによる
