メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
Is there any way to recover the contacts from this phone?
Hi, a friend of mine brought his iPhone 5 to me after his display stopped working. I figured a new screen would sort the problem. After putting a known and tested working screen on the device, it still shows no display.
The phone is otherwise working fine except that there is no display and digitizers are unresponsive on the device (it still buzzes and beeps, and is recognized by the computer). I've told him that he basically needs a new phone as the damage is on the boards side. However, he desperately needs to save the pictures and contacts on the phone.
There is no iCloud on the device but there is a passcode, and without being able to type in the passcode or click "Trust", we can't link it to iTunes. There is also no other computer that the phone has synced with that will automatically pass the "Trust" window.
Is there any way we can possibly get data off this device?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
If the device is not updated past iOS 8, Apple may dump some of the unencrypted content with a search warrant from the police. If the device is updated, no one on this planet can decrypt the data.
However repairing the board itself to get the touch back working might be possible.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Hmm is there any way i can control what is seen on the screen without using the phones' digitizer?
さんによる
Seeing is not important as you need the digitizer to input passcode and tap "trust". You can do that blindly without the LCD working, but no digitizer, no inputs.
さんによる
コメントを追加
Buy This http://www.apple.com/shop/product/MD826A... and Return it after Your Done you can find this at Walmart or Target, Best Buy. keep the working screen on and plug the lightning HDMI adapter and you should be able to get image on your tv so you can unlock the device once you do plug a lightning cable to the adapter and to the pc and you can back it up or save the info he needs. Good luck.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Will try that, thank you so much.
さんによる
Problem is the touch is also not responsive, so the file system cannot be unlocked. There is practically nothing anyone can do.
さんによる
コメントを追加
回答を追加する
Welshhobo さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 151
