メインコンテンツにスキップ
Repair and disassembly guides for Magellan GPS devices.
67回答 すべてを表示
締切られた回答
My gps lights up but does not show a map or talk
I don't use my gps often it just started to go bright, but no screen picture or choices just lights up.
What could this be. do I need to purchase a new one
mg
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
Have you tried to "reset" it?
Depending on the power switch your unit was designed with follow the instructions below:
Slide Switch
If your unit has a Slide power switch then slide and hold the power switch in the off position for more than 8 seconds.
Push Down Power Button
If your unit has a Push Down Power Button, look for a Reset pin hole on the bottom or on either side of the unit. Take a pin or an end of a paperclip and insert it into the hole and push in until you feel it pop slightly, hold it for 10 seconds. Your unit will reset itself.
Reset Power Switch
If your unit has a Reset Power Switch then it will have a three position power switch (Reset, Off, On), if this is the case slide the switch to the reset position and hold it for 10 seconds to perform the reset.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 114
