メインコンテンツにスキップ
2014年4月のアップデートによりアップルの13インチMacBook Airはデュアルコアi5またはi7プロセッサーの更新とわずかなバッテリー性能の向上がされました。
313回答 すべてを表示
Spilled water, which parts to replace?
I spilled water on my 2014 Macbook Air. I had a keyboard cover on, so I don't believe much got into the workings from the top. However, it appears that a decent amount of water got in through the bottom, from what I can tell. I didn't realize how much was in it, so I turned it on a couple times before it dried out, but now it won't turn on at all.
I took apart the entire bottom case according to the iFixit guide (MacBook Air 13インチ Early 2014 上部ケースの交換), looking for signs of water damage. However, there's only one dot that's turned red, on the underside of the battery.
Are there any ways to diagnose which parts of the machine are damaged? Most guides say changes are the logic board needs to be replaced, but since there's no activated water stickers on it, I'm hesitant to purchase another one in case the problem is elsewhere. Is the battery the place to start?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Please tell us more about the spill, what was it, how much, where did it enter the machine.
さんによる
@mayer: The liquid was a diet lemonade, I would say about 1 measuring cup was spilled. It spilled directly onto the machine, but the keyboard was covered with a silicone cover. A significant amount of water pooled under the laptop as well, and I believe it largely entered there (in the seems on the bottom case), but I can't say for sure.
さんによる
コメントを追加
3件の回答
最も参考になった回答
Liquid spills are the hardest things to diagnose. I say that as a professional. I hate them. If your data was not backed up you can probably recover that with a OWC EnvoyPro enclosure. Do your research for a reputable Mac professional in your area and have him (or her) take a look. Try Thumbtack.com.
See what one is selling for for parts on eBay, and what your estimated repair cost will be.
This could be a real money pit.
Contact your homeowners or renters insurance agent and see if you are covered and what the deductable is.
Check with Apple and ask what their "Flat Rate", repair would cost as a last resort.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks, I will look into those. What methods do you use to try and diagnose them?
さんによる
I have batteries and parts in stock, so I just plug a known working battery in.
さんによる
コメントを追加
If you found water underneath the battery then more than likely the motherboard has shorted out and malfunctioned. Sounds like you need to replace at least the motherboard. You may find out that other parts may also need replacing, RAM, hard drive, etc. all depending on the extent of the damage from the water and where the short occurred on the motherboard.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Would that be the same as the logic board? The water stickers on the logic board are all white, so does it still likely need to be replaced?
さんによる
Yes that is the same as the logic board. If the liquid was diet lemonade the sugar from the lemonade could cause corrosion.
さんによる
コメントを追加
Take some pics of the board.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Here are pictures of the logic board: http://m.imgur.com/chDHdnu,ZK02c1h,MoE7q...
さんによる
コメントを追加
回答を追加する
asherlc さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 8
今までの合計 549
