メインコンテンツにスキップ
The Motorola Droid (model number: A855) is a full keyboard touchscreen smartphone powered by Android.
33回答 すべてを表示
How do you re-adhere parts
I have a Droid that is water damaged (no screeen). Was thinking about a LCD replacement, but I'm curious how to re-adhere a lot of the parts that are held together with adhesive, you know, those little plastic exterior covers and such. Does everyone find that re-assembly does not require new adhesives? Does the adhesive that held the original parts together will work again just fine?
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
Thanks. I appreciate the info.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Some adhesives are re-usable and will stick well enough (tape on cables, small internal padding) but the adhesive to hold screens to digitizers or front panels, etc is usually replaced. I do not know if there are replacement strips available for the Droid, like there is for the iPhone. You may have to custom make your own out of double-sided tape.
Here is an example of iPhone adhesive strips:
[リンクされた製品が存在しない、もしくは無効: IF137-006]
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Buzz さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 6
今までの合計 1,451
