Top 2/3 touch screen not working after replacement
I replace my front glass and lcd but power button and bottom 2/3 of touch screen don't work. Any suggestions?
It's probably a defective part. I'd suggest that you replace the screen. Maybe the part was defective.
このアンサーは役に立ちましたか?
Check your work. The power button flex may not be connected perfectly or may be under the logic board. Check your work. The digitizer flex may not be connected perfectly, check your work.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 8
今までの合計 47
