Green Screen Samsung Galaxy S4
The screen was mostly green, discolored, with black spots. No cracks wasn't dropped.
No water damage. And is now mostly black with light brown in some places.
Is it possible to fix this?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
It's a damaged LCD. You'll need to replace that. The LCD goes with the glass and digitizer so you'll need the whole assembly.
このアンサーは役に立ちましたか?
Could you send me a link with what I would need to buy in order to fix it?
And Thankyou!
Okay I think I found the parts but what is the minimum for tools I would need?
If you get the LCD with the frame, then you just need a small phillips screwdriver and a small prying tool. If you get the LCD w/o the frame, then you'll need a heatgun.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 744
