My back cam is not working
i have i pad 4 WiFi resonantly the back camera is not working it only shows a black screen in this kind of problem what should i do to fix it
この質問は役に立ちましたか?
この質問は役に立ちましたか?
First thing first, I would go ahead and check if updates are available for your iOS version. Second, I would perform a full restore of the tablet to make sure the software hasn't crash or anything.
If none of these solutions seem to be working, you are most likely dealing with a hardware problem and opening te iPad will probably part of the deal.
Good luck!
このアンサーは役に立ちましたか?
thanks i did software part i will try with hardware
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 130
