My phone is swictched off
my lava iris x1 atom is switched off now it is not opening is it phone fault or battery fault
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
When you plug in your charger does the phone show that it is charging?
If so, let it charge for a while, then see if you can start the phone with the charger still connected.
If it does start, shut down and then see if you can fully charge the battery. If it doesn't then the battery is faulty and needs to be replaced.
If the phone does not charge with the charger connected, try another charger.
If it does then your charger is faulty.
If it still doesn't charge with a different charger then the charging circuit in the phone or the battery is faulty
このアンサーは役に立ちましたか?
My lava iris 405+ is not switch on why? Charger is in good condition and battery also. I hope u answer my question soon plz reply fast
My Lava Iris X8 when connected to charger turns on and gets instantly of and so on is there any solution for this problem
My Lava R1S with Non-changeable Battery is not switching on, a day before i switched it off and next day switched off I charged it, it was charging but when I tried to switch it on but it didn't. Keep trying to switch it on but nothing is happening, then I connected charger but it wasn't charging only charging light works but when I removed charger light was still on.... I even tired different charger from my friends but same issue. Battery is in normal condition
No idea what to do. Please help me out in this matter... Thanks
My Lava R1S
No display for battery charging
No powering on Screen
No vibration
Tried Power + Volumn Up button together for Hard Reset but not working
Hi @ badar.khayam
All I can suggest sis that you open the phone and disconnect the battery for 5 minutes, then reconnect the battery and check if starts OK.
Here's a video that shows how to open the phone. At 4:12 minutes into the video the battery is seen being disconnected (cable on top left of battery.
You don't have to remove the battery, just disconnect it from the systemboard.
Be very careful when working in a phone. Even though the phone is off there is still power at certain points on the board etc. The Power button is not a power isolating button. It merely signals the operating system as to what the user wants to do. Think of the phone as being in an extremely low power state rather than being totally isolated from the power supply.
Try not to touch anything that you don't have to and also do not short out any components with other components by bridging the tool across two etc
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 15,291
9 件のコメント
my phone was stopped
avishekd123438 さんによる
my phone not turning on
Naveen korumilli さんによる
my mobile not getting oned when it is restarted
Mani Mike さんによる
my mobile shuts randomly
arjun さんによる
My lava iris battery drop up and down
Henry Biney さんによる
4件以上のコメントを表示
