メインコンテンツにスキップ
2011年後期モデル番号A1278 / 2.4 GHz i5 or 2.8 GHz i7 プロセッサー
591回答 すべてを表示
Won't charge battery, magsafe stays green.
I run a small computer repair shop and have done hundreds of repairs in practically every version of every Apple computer but this one has me stumped. Customer came in and the computer laptop would power on and everything would work except the wifi and the fan was on full blast constantly. Very annoying.
I popped it open to find that the previous shop working on this computer LEFT THE HEATSINK OFF THE CHIPS! Since the computer still worked I powered it down, ordered the heatsink and installed it. When I got everything back together the magsafe no longer lights up for more than 2 seconds if at all. I removed the dc-inboard and gave it an alcohol bath and re-flowed the solder and now it lights up, but stays green and doesn't actually charge the battery. I'm completely bewildered and would appreciate any help or diagnostic steps!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
reflowed what? What does it say with a known good OEM 85w charger attached and battery connected? battery not charging, or an X on the battery?
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
I reflowed the solder in the DC board. The laptop does not lower up so nothing shows on the screen at all.
さんによる
Get a new dc in board, these things are five bucks. Try turning it on by shorting SMC_ONOFF_L to ground. What voltages do you get for PM_SLP_S4_L, PPBUS_G3H, PP3V42_G3H, PP5V_S5, PP5V_S3, and PPVRTC_G3H?
さんによる
Hello @zzz. I unfortunately don't have a schematic. Any advice on where I'd be able to find one?
さんによる
コメントを追加
回答を追加する
amer jarrah さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 357
