メインコンテンツにスキップ
The PowerShot S110 has a 12.1 Megapixel High-Sensitivity CMOS sensor and DIGIC 5 Image Processor, 12-bit multi aspect RAW+JPEG, 24mm Wide-Angle, f/2.0 lens with 5x Optical Zoom and a sleek pocket-sized body.
Is it possible to replace the flash light?
Because the flash light is not working I want to replace it but I don't know if it is possible. I can't find anything about replacing the flash light and I don't wanna open the camera without knowing it. I can't find a replacement item either.
If anybody knows anything about this, please let me know, thanks a lot.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
Yes, it is possible.
You have to exchange the "Canon PowerShot S110 FLASH ASS'Y Replacement Repair Part".
This is hard to find but i got it on http://www.ebay.com/itm/Canon-PowerShot-...
Use the dis-assembly instruction for the display and remove further the copper foil under the display to find 2 further screws on the camera backside, remove these and also one screw on the assy frontside. Carefully disconnect the foil plug of the build-in assy and you can easily do a drop-in replacement of the assy.
My camera is again working.
Never manually push-in the flash of the camera. This will destroy the camera flash assy.
Good luck ;) !!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
i also have this problem with the s100..flash will not fire..the flash raises up..the program is set on flash..however, will not fire? have no idea why? if someone can give me advice to fix the flash..please give to correct my problem...thank you..
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
justtrying さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 16
今までの合計 1,805
