メインコンテンツにスキップ
Upgrading the memory to 1GB
I wanted to ask if upgrading the memory to 1GB is best if were are also upgrading to Leopard from tiger and running mircosoft, we just wanted your input before we purchase the PC2700 1GB ram chip from you $54.95 our ibook G4 has 256MB currently model A1054.
Thank you for your help we look forwrd to hearing from you soon,
Jarry, Trisha
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
As for the RAM not showing up in system profiler, look at my answer below.
さんによる
コメントを追加
4件の回答
最も参考になった回答
Hi! Yes, the 256MB is on the logic board, so once you install the 1GB module, you'll have 1.25GB. All iBooks have some RAM on the logic board (which is both a blessing and a curse, depending on the situation). Because it's integrated, no, you don't have to remove it.
I don't know if you've installed Leopard yet, but hopefully you have at least a 933MHZ laptop, because it won't install on the 800MHZ model due to the system requirements of Leopard.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
さんによる
+ agreed
さんによる
さんによる
コメントを追加
If the RAM does not show in system profiler then it is either not seated properly, it's bad, or simply not compatible with your machine. Please remove and re-insert the RAM stick, this time making sure you feel a slight thump when it is completely inserted. After that, perform a SMC and PRAM reset, which is always a good idea when introducing new hardware to a Mac. As far as the 256MB RAM, like RDKL pointed out, that is integrated into the LogicBoard itself and is not removable.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Good catch, I didn't notice Jarrymar stated it wasn't recognizing the RAM.
さんによる
さんによる
コメントを追加
You will definitely see an improvement no matter what you try to run.
I upgraded from 512MB to 1GB and was amazed at how much that mattered. And the install is very easy.
Do a price search online, though, there is a huge range in prices for the same chip. I got mine for about $40 shipped.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have follow up questions about the upgrading of memory for our ibook G4 12" 800MHz-1.2 GHz model number A1054 I followed the instructions on ifixit to install the new memory chip 1GB PC2700 my first questions is were is the original 256MB chip it wasn't in the slot up the silver cover after I removed the airport card and cover? also wanted to know does the 256 need to be removed I honestly don't see it is it built in?
I would really appreciate the help at this point I installed the 1GB chip in the empty slot but the ibook doesn't register when look under about this mac is still show 256BG.
Thank you,
Jarry, Trisha
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The 256GB is soldered to the logic board
さんによる
コメントを追加
回答を追加する
jarrymar さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 7
今までの合計 12,150
