メインコンテンツにスキップ
First released in January of 2014, the Pebble Steel is a steel-bodied Smartwatch from Pebble Technology Corporation.
7回答 すべてを表示
My Pebble steel isn't vibrating when I receive a new notification
My Pebble Steel watch is not vibrating when I receive a new notification. I can still see when I get a notification because it pops up on the screen but I don't feel the vibration. I have made sure that the settings on my phone and watch are both set to vibrate for a new notification. What else can I do?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
that fixed the problem. thanx.
さんによる
コメントを追加
6件の回答
ベストアンサー
Also, try visiting the troubleshooting page for more help.
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
最も参考になった回答
Mine was in Quiet Mode. You can change this in the settings. You can also change this by holding down the button on the left side of the watch while at the watch face.
このアンサーは役に立ちましたか?
スコア 18
12 件のコメント:
Worked for me, i feel so stupid now
さんによる
Mine was not working either, Supid #2! Thanks!!!
さんによる
Wow! Thanks! *face palm*
さんによる
Add me to the dummy list! Thanks for the help
さんによる
Not working. Howwwee
さんによる
7件以上のコメントを表示
コメントを追加
Try resetting the watch.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
I reset it and it only vibrates on phone calls.
さんによる
I reset mine nothing, no vibrating at all. I'll try again.
さんによる
Though it works, feels over kill. Try the quiet mode
さんによる
コメントを追加
No solution worked. No vibration at all even after hard reset
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
My pebble steel started to vibrate again, after android wear app was removed
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I had same problem after installing Android Wear. I took 'belt and braces' approach and deleted AW app and also did a factory reset on the watch and signed in with a new account to make sure I really was back to 'factory settings'. I chose this boots-and-all approach as I had previously also installed a new watchface (Beacon) which screwed the watrch up completely and caused it to reboot at random times and I wanted to make sure I had totally got rid of it.
さんによる
Thanks. I m on the top of the dummy list!!
さんによる
コメントを追加
Just discovered this:
Notifications will appear, but not vibrate, when the Pebble Time is charging.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Orlandria Heggs さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 14
今までの合計 15,574
