メインコンテンツにスキップ
2012年3月16日に発表されたiPadの第3世代モデルです。4GとWi-Fiモデル用の修理ガイドを公開しています。修理には温めて慎重にこじ開ける作業が必須です。
20回答 すべてを表示
Why is my replacement screen not sticking properly?
I ordered and replaced my busted ipad 3 glass using the instructions i obtained from ifixit. The instructions were very useful and installation was a breeze. I cleaned all the surfaces that the screen attaches to so the tape would adhere better using some light solvent being careful not to damage any internal components. For the first couple days after the repair all was well. The screen however keeps popping up along the bottom edges and I can not seem to keep it from coming up. I tried using some heat where the tape is and placed some weight on the bottom edge but the issue still exists. Please help. Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Make sure it's not the digitizer flex cable pushing the screen upwards. Is it the bottom left corner?
さんによる
Same situation with my first fix and the digitized flex cable seems to be the culprit. How can this be solved?
さんによる
コメントを追加
2件の回答
最も参考になった回答
You will need to buy Red Tape. If it came with the black tape or 3M tape is useless i fix more than 10,000 ipad screens and those tapes are not the best the Red Tape i guarentee you you wont have that screen lifting problem .
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Where can i obtain it from? Will i need to remove the entire panel and re tape the whole thing?
さんによる
You Can Get it on Ebay and Amazon, Yes you will need to re-tape everything or you can just tape the area is just lifting.
さんによる
I am having the same issue, with the glass not staying securely attached to the iPad. I went to amazon.com and typed in "red tape for iPad screen repairs" and 6 digitizer replacement screens turned up, showing the red on the back of the digitizer glass, BUT it only seems to come with the WHITE front border trim, and not the black. Is the tape itself sold separately?
さんによる
Holy cow , that is an extraordinarily thin tape.
I watched this on youtube. Is this the gel like red tape you're referring to?
www.youtube.com/watch?v=Hy81hhvfX-s
さんによる
コメントを追加
some times the adhesive needs some heat to activate properly take and clamp it in place and see how that works
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
stiman82 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 18
今までの合計 2,652
