メインコンテンツにスキップ
The Beiens Cartoon RC Race Car is a toy made in China designed for kids 18 months and older. It comes with a removable race car driver figure and a remote controller. The race car requires 3 AA batteries, and the remote requires 2 AA batteries. The batteries are not included in the toy.
3回答 すべてを表示
Why won’t the car turn on?
My car won't turn on
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
Check both the remote control and the toy car to see if the batteries are properly in place. If they are, try replacing the batteries with a fresh set.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Some cars have batteries that must be replaced, whereas others are rechargeable. Charging may take a day or two, but depending on the car, it may be normal. If you do not have a charger, I recommend buying another, or if it is an older car, the chargers may only be sold on sites where you can buy a gently used charger that is inexpensive, and fits the make and model of your toy car. If these techniques do not work, I would suggest seeing a specialist to see if there is possibly something wrong with the remote, or the connection between the car and the remote.
I wish you the best,
Jolie Summers
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
No just the batteries, but also some cars have a black fuse or can be a relay that is bad.
Check the fuse with a tester both sides or pulled out and check the inside if is broken and replaced, and saw the relays.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Rechargeable batteries are dead
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Amber Ashley さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 289
