メインコンテンツにスキップ
7つの異なるジェネレーションから成るiPod Nanoモデル
1007回答 すべてを表示
締切られた回答
need the illustrated diagram of menu function
Cracked the dis[play on my 1st or 2nd gen nano-but it still works- need to know (by way of sound) what each click from the "home page" means- playlist, artist, song, etc....in what order?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Here is a picture of it:
http://www.best-ipod-online.com/images/u...
If that's not the same model you have, just search google images for ipod nano menu or something similar.
If that doesn't match up exactly then it probably means that you have changed the items on this menu to be different than the original factory settings. You can use iTunes to restore it to the original firmware to reset it.
--O
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
For a second gen nano, the default main menu is this:
  • Music
  • Photos
  • Extras
  • Settings
  • Shuffle Songs
And of course, when you are playing something, "Now Playing" is tacked on at the bottom.
Clicking Music will bring you to:
  • Playlists
  • Artists
  • Albums
  • Songs
  • Genres
  • Composers
  • Audiobooks (if you have any)
Compilations may also show up if you have that enabled in settings. I think the default is off. Search is present at the very bottom on second gen but not first gen models.
If you have a first gen nano, the above listing should be the same.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,302
