メインコンテンツにスキップ
The Stealth-G4X is an Android tablet that was released by Mach Speed in 2014. It has a 7.85 inch screen and operates with Android Kit Kat 4.4. It has a resolution of 1024x768 and a Cortex A7 processor with speeds of 1.50 GHz.
Why would the camera on this tablet not work?
What would cause the camera of this tablet to not take pictures and stop working.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
There are various causes for your camera to malfunction on the Trio Stealth-G4X. These include low battery, a dirty lens, not enough storage space, or a damaged camera.
If your tablet has a low battery percentage, your camera application may refuse to open or take pictures. Try charging your tablet and attempting to use the camera at a later time.
If your tablet seems to be taking blurry or dark pictures, your lens might be dirty. Gently wipe the lens with a clean, soft cloth.
Your tablet may refuse to take photographs because your storage is at full capacity. Be sure to check and see if your storage is full in the settings. If this is the case, you should delete some of the existing photos on the device or use a MicroSD card for additional storage.
Your camera may be unresponsive because it is damaged. If this is the case, it will need to be replaced.
For additional help and answers to similar questions, please visit the Trio Stealth-G4X troubleshooting page.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I try to download camera but it still not working
さんによる
コメントを追加
回答を追加する
Riley Briggs さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 625
