Why is my charger for ipad 2 gets hot?
when charging ipad 2 charging adapter gets hot.
Chargers getting hot is normal because about 220 to 240 AC volts are converted in the charger to 5 DC volts. Chargers contain components like transformers, resistors and capacitors (among others) which gives off heat under normal load.
Charger getting hot should not be a problem unless it happens even when the device (iPad in this case) is not connected.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 11,492
