メインコンテンツにスキップ
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
150回答 すべてを表示
締切られた回答
2005 grand am overheating
my 2005 grand am is overheating according to the temp gauge. the gauge will go up to 130 and the high temp light will come on but only stays on for approximately 5-10 seconds then the gauge goes back down to 90. it hovers between 90 and 100 degrees but doesnt exceed that. we have replaced the intake gaskets, thermastat, we have added a can of head gasket fix but it continues with the temperature going up then coming back down. our mechanic is stumped and is questioning the head gaskets to be replaced which is quite costly. any suggestions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Get a temp gun and see if its actually overheating first. I would have done that before throwing in a can of head gasket fix. That stuff is nasty and only meant as a temporary fix. Why were the intake gaskets replaced?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
So sorry I left out an important piece of info...2 weeks prior to the intake gasket being replaced my daughter noticed the low coolant light come on so added 1 litre of antifreeze
Approximately 1 week after that noticed again the coolant light so added another litre of coolant
Our mechanic thought that it was the intake gasket needing replacement due to this
Sorry for the omission
さんによる
Also just spoke to the mechanic
He said while he had it the check engine light came on so he plugged in to his machine and it showed a misfire
さんによる
Sounds like a headgasket to me.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 296
