メインコンテンツにスキップ
Repair guides and support for the 3rd generation Ranger, a compact pickup truck manufactured by Ford.
78回答 すべてを表示
O/D light blinking after 20 minutes
The O/D light on my 2004 Ranger with a 5R55E transmission is blinking after about 20 minutes of driving. The code is P0735, "gear 5 incorrect ratio." It shifts fine before the light blinks. Even after it blinks, it drives fine in gear 5, but once the light blinks, shifting is abnormal. Might changing the TR Sensor help?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Bob DeCamp, this is going to be tough on. This could be as simple as
- Low transmission fluid level
- Dirty transmission fluid
- Shift solenoids
after that you could be running into major issues. It could be a valve body problem as well as the front (OD) servo or a bad OD band (unlikely since your trouble start after some driving). I'd start with simple (inexpensive) to complicated (expensive) as well as a good manual
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Fluid is clean and at correct level. Can front (OD) servo be changed without removing tranny? What about the question of the TR Sensor?
さんによる
コメントを追加
Can low transmission fluid cause the od off light to come on
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Low levels can cause the light to come on . Dirty fluid can also cause this problem . Fluid that's loosing its viscosity can also do be a cause
さんによる
コメントを追加
Would a shift kit fix this issue? I'm having the exact same problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Bob DeCamp さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 40
過去 30 日: 202
今までの合計 18,932
