Why isn't my tablet working
My tablet wont come on
There may be a problem with the battery or charger, check out the Troubleshooting Guide for more information.
このアンサーは役に立ちましたか?
Have you tried charging the battery? If you plug in the tablet but the battery won't charge, the battery adapter may be broken. If so, try using a different battery adapter and see if that works. If you have exhausted these options and the tablet still does not turn on, then the problem may be with the tablet itself. In that case, you could try replacing the battery in the tablet because it may have run out of juice.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 171
3 件のコメント
What have you tried? Charged it? New charger;new cable?
oldturkey03 さんによる
Can you try to describe your problem in detail? What is the situation of your tablet now?
William さんによる
My touch isn't working at all. Power and volume buttons are but no touch???? WATS wrong
zionwh123 さんによる
