メインコンテンツにスキップ
Repair guides and support for Android tablets made by Dopo, also known as Double Power.
How to reset tablet with no volume buttons?
My sister bought me a dopo 7" kitkat tablet with no volume buttons almost 2 years ago and my brother borrowed it but to give it back to me, he reset it but put my password back for me but it seems he put the wrong one as it won't let me in. I had him try to get it back unlocked but it wouldn't work. So now I'm stuck with a locked up tablet.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 45
17 件のコメント
i forgot my trio tablet password and my face lock has to reset and pressing volume up button and power on button won't work and i have been trying to remember my password but my memory won't jog back to me so now i'm stuck with only a laptop that i can only use in safe mode
さんによる
Hey I have a really old android tablet and I can't Remember the password and the volume button bar thing has come out and I can't seem to press the volume buttons any ideas how I could reset it
さんによる
I have this problem with my tagital tablet. Volume buttons are broken but need to reset it somehow.
さんによる
Hi Nicole,
Is the plastic bar of the Volume buttons actually broken or is it that nothing happens when you press them? The above procedure is for a Dopo tab and is slightly different to what you need to do for a Tagital tablet, as best as I can find out. You need to press and hold the Volume Up button "first", then press the Power button, so that you are holding both buttons until the recovery menu appears. After that it should be the same.
Make sure, if you can, that the battery has some charge in it before you try to reset it. Also do not try a reset with the charger connected. If you can start the reset process, when it is resetting, be patient, it takes a few minutes to complete.
さんによる
I have a problem with my RCA viking pro tablet. The dog logo appears and the viking pro logo appears and turns off for no reasons and cant reset it.
さんによる
12件以上のコメントを表示
コメントを追加
8件の回答
最も参考になった回答
Ok everyone. I had this same problem came to Google and read everything it seemed to fail for everyone that has tried.. I contacted the company and it was hard to communicate with them do to language differences. They emailed me the factory reset process. To get past being locked out of your tablet you must do a factory reset. The instructions they sent me did not work lol. I was very frustrated so I started trying all combinations that were possible. This is how I actually successfully fixed the tablet.
1. Press the power button to get the option menu for
Power off
Reboot
Silence phone option.
2. on that menu you have to hold down that power off option on your touch screen while also holding down the home push button on the side of your tablet.
3. This brings up a screen to reboot into safe mode..(these are the 3 steps the company does not tell you that is why no one gets it to work.
4. HIt yes for safe mode and then hold down your power and home buttons on side of tablet till the dopo Logo appears.
5. Release both buttons and hit the power button one time and then hold only the home button down till a menu option appears.
6. Use the home button to move down to factory reset and press the power button to select. Once it says complete then use the power button to select reboot.
Problem solved. Hope this will help everyone out.
このアンサーは役に立ちましたか?
スコア 25
24 件のコメント:
That works only problem with mine jsbwhen i get to the screen that says whipe everything clea. I have three options of no and i cannot say yes. So then it wont let me do it..
さんによる
Thank you!! I just bought my daughter a tablet for cheap because of the password lockout
さんによる
My tablet will not show the yes for the Safe mode... Can u help me please
さんによる
SHANESE
1. press to power off
2. on menu option (power off, reset..), press option "Power off" (in touch screen), and no release your finger. Same time, press "home" (phisical button, near to power on/off buttom)
Then, continue with normal step 3.
さんによる
it doesnt work for me ........ what i should need to do..
さんによる
19件以上のコメントを表示
コメントを追加
press the power button and turn it off then press the power botton and the volume botton at the same time
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
there are no power buttons
さんによる
My son forgot his Samsung tab A pin and he doesn't know how to reset it please reply and tell me
さんによる
コメントを追加
HI.
I had the same problem and the only solution was via SDCARD. You have to download a right firmware for your tablet and put in a SDCard like this:
Here is instructions in this tablet without volume keys and Home key. Everyone asks how to do the recovery:
upgradeable via the SD-card:
1. Unzip the contents of the archive to the root of the SD-card;
2. Insert the card into the tablet and switch it off;
3. Press the power button + reset at the same time.
4. Release the power button and after 2 seconds the reset button.
If you did everything correctly, wait a little and you will see the display of the update process.
In the case of successful update a caption that the card will be learned. After that, remove the card and restart the tablet (after reset).
After the software update be sure to do a factory reset via the menu android.
If after the update does not work for touch screen -. In your hands is a tablet other revisions
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I have a Hisense Sero 8 pro. It has only a power button. How do I reset...there is nothing in the reset hole either.
さんによる
I have a tablet with no hame button how do I facto reset it?
さんによる
コメントを追加
Thank you !!!
"That works only problem with mine jsbwhen i get to the screen that says whipe everything clea. I have three options of no and i cannot say yes. So then it wont let me do it.."
Tiffany, i had the same problem.
Push the home button again and the "YES" option will appear.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
When the device is turned off, hold down the esc. button and then hold down the power button until the device reboots. The device will reboot with an options screen. Select the option to clear the device and reset to factory settings. Once that's done it will go back to the options menu. Select to reboot the device and it should be unlocked when it's rebooted.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
My tablet as no volume key, and I can't remember the pattern lock. Pls help me with how to reset it..
さんによる
コメントを追加
if it has a home button, you need to hold the home button down for 2 seconds and then quickly hold the power button on for 2-3 seconds. also, remember that the home button is to go up and down the recovery list and the power button is to select.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
We dont have a up n down
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I have a rca with no volume how do i reset it
さんによる
Sir, I have 10.1" Polaroid 2014 Tablet has no volume key. It starts with Polaroid logo and pause on next screen with color strip and "Internetablet" caption. I did all efforts to work.
さんによる
コメントを追加
I also do not have the volume button. But need it reset. How?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Eliz Williams さん、ありがとうございました!
統計データ:
過去 24時間: 16
過去 7 日: 57
過去 30 日: 248
今までの合計 157,730
