メインコンテンツにスキップ
The Roku 3 (Model: 4200) is a third generation streaming device released on March 5, 2013. Connect to any television or video display with correct input connections to stream available content.
12回答 すべてを表示
How do I turn off the front panel LED light?
The LED light on the front panel of the Roku 3 is constantly on, and at night the brightness of the LED can be annoying. Is there a way to turn off this light?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 10
3 件のコメント
HOLY CRAP!! This is real. EVERYTHING worked, even the L.E.D. option!! THANK YOU SO VERY MUCH!!!!
さんによる
Hi, Mary here. LED lights can be blocked with inexpensive black electrician’s tape. But if an LED is close to the Infrared Portal that receives commands from your remote, you might block the Infrared Portal and thus prevent commands from getting from your remote to your TV or other devices. If that’s the case, there’s a product made by Anytime Sign called Infrared Magic Black self-adhesive 1.5 Mil Mylar Sheeting that can be placed over the area to block the LED light while allowing the transmission of IR commands from your clicker to your device. The product is described at
www.anytimesign.com/LED_BLOCKER
さんによる
Very funny. BS. DOES NOT WORK.
さんによる
コメントを追加
12件の回答
最も参考になった回答
On your Roku remote hit follow the sequence: home button (5x), FF, Play, Rewind, Play, FF - this gets you into a secret menu. Choose adjust LED brightness and you can reduce the white LED light to 0%. :-)
このアンサーは役に立ちましたか?
スコア 12
20 件のコメント:
i thought this was a joke but on a whim i tried it and its real. hilarious
さんによる
this works!!!
さんによる
The menu is real. Unfortunately the LED option is not.
さんによる
Yep this works. I can still see the light at night even at its lowest setting, but it's much better. Couldn't believe it worked. Lol
さんによる
The LED option was there for me. Thanks.
さんによる
15件以上のコメントを表示
コメントを追加
Home > settings > system > power > Standby LED ...select off
このアンサーは役に立ちましたか?
スコア 8
7 件のコメント:
thank!!! youuu!!
さんによる
All the other answers are saying there isn’t a solution or there is still some visibility. This turned it off immediately and took 5 seconds. Thank you!!
さんによる
Perfect, worked for my new ROKU 5 Series 4K HDR
さんによる
Thank you, that light was very irritating.
さんによる
Thanks this solved the issue!
さんによる
2件以上のコメントを表示
コメントを追加
There is a way to do this. After you finish watching your programs from your Roku player just click on the top Home button icon that will take you back to the home page on your Roku. Once there select on your TV remote the source button and select TV or Cable TV, which ever one you have. Once it's back to the TV then turn off your TV. The Roku box will shut off, light and all, between 15 min to an hour. If you do not exit what you are watching on your Roku it will continue playing the programs. That's why the light stays on.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
This works. Took only 10 min.
さんによる
That is not totally true. It should normally go off but sometimes it will stay on and sometimes it will come back on. When it stays on too long the Roku box will become extremely hot.
さんによる
コメントを追加
For all of you who have been wondering how to turn off your Roku 3 device well it's true there is no way to turn it off but to unplug it. I have found a way to turn off the light and allow it to go in to "sleep mode". You can pair it as an Anynet+ device on your TV. Then on your Roku settings go to Screensaver and put your time setting to 1 minute. So when you get ready to turn off your TV, press the home button on your Roku remote so it will not continue to stream, then turn off your TV. The LED light on the Roku will turn off automatically within one minute. I hopes this helps everyone. Advance to Roku offer an off switch on your devices. If you add an additional setting to where the consumer can set when they want updates to be installed, they can be sure to have the device on at that time so that the update can begin. This will give your customers a peace of mind with your product.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thanks! This worked!
さんによる
コメントを追加
Thank goodness!! This worked. I love my Roku, but that light was way too bright. I used to put something in front of it so I could sleep. I used the
Home>Settings>System>Power>Standby LED
and it worked, gave me the option to turn light off completely. Thanks so much! So glad I found this forum.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
There is no official way to do this. You'd have to unplug the power source. You can use your TV as a remote but that requires setting up and a SmartSwitch.
The Roku 4, to date, is the only device with some sort of way to power it off. You can read more about it https://www.orduh.com/turn-off-roku/,
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
コメントを追加
Put Black tape over the light
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
For those who are trying to turn your roku box off/on.Buy a single three prom plug with a on/off switch on it. Less than 5 bucks at Amazon.Problem solved!:)
さんによる
コメントを追加
Hello,
At the point when the LED lights on the front board are on, the Receive and Send LED lights can be changed from strong Blue to Green with the goal that the majority of the lights are similar shading. This is very easy to turn off the front panel LED light, just go to the Configuration link on the main menu and click the turn off front panel LEDs except power LED drop-down menu and select Enable. For more help visit https://www.roku.com/ and read some instruction. If you need some instant help then visit here and get instant help. http://www.customer-support-numbers.com/...
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Home. > settings > system > power > standby LED select “off”
さんによる
This worked perfectly! Thank you for posting...that light was driving me nuts. (The secret menu posted above to dim the light also worked, but didn't turn it off. This actually turned it all the way OFF!)
さんによる
コメントを追加
Hello. If you are in search of any technical help for Roku 3 device, then just call Roku Support Number. Here, you can directly talk and discuss with the highly professional and skilled team for all your issues. You may call this customer care number anytime.
For more informatio, you may visit: https://goo.gl/9zLXkN
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
As much as I know, you can't turn off the light, you can only dim it. The only solution to get rid of that annoying light is to either unplug your TV when you sleep or to cover it with something. Some people say that there is a "sleep mode" option, but I don't know if that works or not. I didn't try it, because, for me, this light is not a problem I even like it. I've also ordered LED lights from ukled.co.uk in the dorm. I don't like it when it's totally dark in the house, it doesn't feel secure.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Just go to settings - system settings - turn off standby light
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
On your Roku 50S435 model.
When your TV is off, the standby LED in front of the TV will be turned off by taking these steps.
-Settings
-System
-Power
-Standby LED
-Off
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kasey Evans さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 20
過去 30 日: 115
今までの合計 110,313
