メインコンテンツにスキップ
Repair guides, user manuals, and service manuals for the Acer Aspire V5-573pg. This thin and lightweight 15.6-inch laptop was produced between 2013 and 2014 and was designed for everyday use, balancing performance and portability.
Acer V5-571 Series BIOS Locked and need code / Help
When trying to boot to the OS, I get an error 0xc000021a and the PC continuously tries to reboot.
If I press F2, I get a dialog box with Password/Unlock Key and the code 11DAA97B.
I am trying to get it to boot to CD so I can re-install Windows.
I tried entering a code from http://bios-pw.org, but it did not work.
Hopefully, somebody can help with this issue.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 9
22 件のコメント
what the unlock key hint number a42eb255
さんによる
68069b26
123456
さんによる
What the unlock key hint number 94CF3C43 Acer Travelmate 8573TG-2624G75
da Ivano
さんによる
Whats 5he unlock key - 4B43313E
さんによる
password/unlock key : .........
unclock key hint number 5ce4c08f
さんによる
17件以上のコメントを表示
コメントを追加
3件の回答
ベストアンサー
On the Acer Aspire V5 series, if you open the bottom cover and remove the RAM you should find a couple of pads on the board labelled G2201. Remove the battery and power cord from your machine. Use a piece of wire to short those two pads. While holding the wire, plug the machine back in, then hit the power button. This should clear the password. I had to do this a number of times, but what finally worked was to hold the power button down while the machine came on, then shut off. I cycled this a few times then eventually the password was removed and I was able to get into the BIOS setting screens. Good luck!
このアンサーは役に立ちましたか?
スコア 20
21 件のコメント:
Hi, thousand thanks to you. I thought I loss my laptop. Fortunately your answer help me out. God bless you.
さんによる
Thanks, I helped!
さんによる
I tried a lot of things to get this laptop fixed for a friend of mine. Your info did it. Thank you to put this information out there ;-)
さんによる
Hey tom, I opened up the laptop, took the out and I can see only one G2201 and the other two are G2101 and G2701. So I was just wondering which ones do I short out. I'm using the Acer aspire v5-571. Please help me out it would be greatly appreciated. Thanks
さんによる
Thanks a lot, you helped me...
さんによる
16件以上のコメントを表示
コメントを追加
You can Just buy Your Password at http://biospassword.tech Choose ( Acer ) and take it from there or here is the direct link: http://biospassword.tech/acer-bios-and-h... tested and working even on laptop built in 2018
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
This worked on an Acer A717-72G from 2018, which had a corrupted BIOS password (the password was known to be 1234).
The key to unlock arrived after roughly 90 minutes.
さんによる
コメントを追加
The solution suggested by Tom Stephenson above worked for me, I was using a wire from an audio cable which wasn't working for me at all, I guess because it has too many little fibre cores. I then tried using a wire from an ethernet cable cut out a coloured piece snip both ends and place each end on the G2201 copper triangle pads. Worked first time hold the wires in place then press the power button and hold.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
John Presler さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 29
過去 30 日: 131
今までの合計 44,341
