メインコンテンツにスキップ
Released in 2012, the Samsung ATIV Smart PC 500T is a 11.6", Windows-based Samsung tablet computer with 1366x768 pixel LCD, 64GB of storage capacity, and a processor capable of running up to 1.8 GHz.
My tablet and keyboard keep coming apart?
The keyboard often stops working when I'm typing
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Why Stock keyboard they tell to change keyboard layout language?
Pls. Help Me....
さんによる
コメントを追加
2件の回答
ベストアンサー
Try disconnecting and reconnecting your keyboard, making sure you place it firmly. If it’s still not working try cleaning out the keyboard connections on both the tablet and the keyboard with a dry cloth, checking for any debris, before reconnecting it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
With the tablet removed from the keyboard, push in the release button at the top of the keyboard (which you push to release the tablet) and look at the small plastic hooks on left and right they need to be both undamaged. Typically some people get frustrated and try to pull the tablet free and that breaks off one of the small hooks. If one is broken, too bad, so sad.
If both look the same and one tip or two are not broken off/damaged, then clean the contacts as suggested above and then I suggest you push down evenly when you reinsert the tablet and then sort of gently push down on left and right side top edges of the tablet to make sure the little plastic tips on the holder have best opportunity to hook onto the attaching holes in your tablet's bottom edge.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
My right little plastic hook thing broke when it was shipped. Is there a way to replace it?
さんによる
コメントを追加
回答を追加する
Marissa Santana さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 1,490
